Air Conditioning Post issues with air conditioning here
blowing warm air everything else seems OK?
Old Jul 12, 2019
guitarsnlikker's Avatar
guitarsnlikker is an unknown quantity at this point
I noticed that the ac is taking longer to get somewhat cool air coming out. 2005 civic 289,000 miles, original ac compressor as well as other parts of the ac system are original.
Today I checked pressures. Air temp in central Alabama today was about 90deg humidity about 60% . Low side was 50psi, high was 240psi with ac on car running warm engine. Air coming out of the vents was about 65deg. When I turn ac off low side climbs and high go slower as expected. To me the numbers indicate the refrigerant levels are OK, clutch is engaging the compressor, I watched it do that many times. Fan's turning on. Only thing I can mentioned that may be unusual is that after shutting off the ac the high side does drop to about 200 or so then when I tun ac back on it seems to take some time to get back to 240psi.
Why am I getting 65 deg air? I dont know. Little help please?
Perhaps unrelated issue... a couple times in the past couple weeks I smelled burning metal and or burning rubber. Haven't smelled since, but it was very noticeable on those occasions. I have been unable to determine where that smell was originating from. There is no smell now.
Thank you
Old Jul 14, 2019
GolNat's Avatar
Prelude Owner
Re: blowing warm air everything else seems OK?
Rubber smell could be a belt slipping how do they look?
Has the refrigerant ever been topped off?
darthtony360
May 1, 2016 09:58 PM
mrohitredd
May 30, 2015 06:51 PM
TryllZ
Jul 8, 2014 07:25 PM
sdraza1
Sep 4, 2013 09:11 PM
01civicexboy
Mar 20, 2006 10:46 AM
