Regular Maintenance Post Questions/Information about Regular Maintenance here
2010 LX-S 100k miles service
Old Feb 11, 2021
chuffsy's Avatar
chuffsy is an unknown quantity at this point
Is there such a thing as a 100k miles service?
Anyhow my sons 2010 LX-S is about to hit the 100k mark. This car has been a gem so far. Not counting regular maintenance I have only done three repairs and they are as follows.
The cv axles were replaced under warranty at 25k miles. Apparently there was a bad batch that was not lubricated enough.
I installed a new bump stop in the strut assembly there was a faint knocking sound on the left strut.
Lastly I installed just recently two camber bolts to adjust the camber as the specification had gone negative.
Thats it!!! Not complaining one bit.
So , as far maintenance , not counting oil and cabin air filter , brakes , this is what I have done in the almost 11 years of ownership.
Three Transmission fluid changes at 26k , 50k and 75k ,drain and fill method and each time draining and filling about 2.5 qts 3 times. Three brake bleeds. On power steering fluid change. One coolant change including thermostat and radiator cap renewal. Clean EGR valve though it was fine.
So now I am thinking , beside the usual service stuff , to do the serpentine belt and tensioner , spark plugs.
Any other suggestions , rad hoses? Any vacuum hoses ? Anything at all that has been problematic with high mileages.
Kindly let me know.
Regards
Old Feb 11, 2021
Re: 2010 LX-S 100k miles service
https://owners.honda.com/vehicle-information/manuals
Old Feb 11, 2021
chuffsy's Avatar
Thank you for the link. It appears I have done quite a few things preemptively.
Old Feb 12, 2021
FRSam's Avatar
Click Here
That's not always a bad thing. Better to do that than to leave it too late. Sure, it'll cost more in the long run, but it's worth it if you plan on keeping the car long-term.
kaleameya
Jul 19, 2017 05:20 PM
speedlever
Dec 3, 2015 09:29 PM
mrohitredd
May 28, 2015 10:03 AM
scott37300
Dec 14, 2010 05:29 PM
charlios
Mar 16, 2004 07:14 AM
