Air Conditioning Post issues with air conditioning here
AC compressor cycling strange
Old May 27, 2024
pippo's Avatar
pippo is an unknown quantity at this point
People,
2001 civic EX, blows ice cold air, but the compressor cycles on/off about every 3 seconds, but mostly this happens when car is started up, for about 5 minutes. PSI low side goes from 30-55 or so. Then down again, of course, all over again. Sometimes the comp cycles for longer period, which I believe is normal, say, every 15 seconds. But during a drive, it has been know to completely stop blowing cold.
Any idea why this happens? Pressure switch starting to go?
Thanks, people.
Old May 28, 2024
BrotatoChip's Avatar
Super Moderator
Re: AC compressor cycling strange
Check the compressor clutch gap clearance. If it's too wide the clutch can slip, causing heat, eventually tripping the thermal protection.
billybob1995
Air Conditioning
Feb 26, 2023 09:17 AM
Timbogates
Air Conditioning
Aug 19, 2018 04:34 PM
atl01
Engine Swaps
Aug 12, 2007 10:23 PM
Dakker
Nov 6, 2005 03:46 PM
AzNmiKex215
Apr 9, 2005 07:47 AM
