Air Conditioning Post issues with air conditioning here
A/C Blows Cold but car jerks & engine vibration & noises
Old Jul 19, 2022
soupD2's Avatar
soupD2 is an unknown quantity at this point
2004 Civic Ex, I bought the car last year, a/c working and blowing nice and cold. Was getting belts changed and the a/c line to the right of the engine cracked and started leaking. It was temporarily taped up and wasn't a concern since it was winter. Eventually I bought and had the line replaced as well as a Freon recharge. It seemed great, drove a while down the highway back home with the a/c blasting cold air. Few days later I turn on the a/c and start driving, going about 45 and the best way i can describe this is it felt like a ghost was pushing on the gas and brake making my car buck/jerk every few seconds. It drives horrendous and feels like its about to break down if I keep the A/C on.
I checked under the hood during idle and a/c on, the engine visibly shakes significantly more when the clutch engages
There are also buzzing/rattling noises that occur but I haven't pinned down where its coming from.
Anyways, I am not experienced at all when it comes to this stuff so everyone I talked to has said to just replace the a/c compressor & drier but that is in fact not cheap so if I could get any help with pinning
down the culprit, wrong amount Freon, clogged system, etc., before pulling the trigger on the compressor, I would greatly appreciate it!
Old Jul 19, 2022
Colin42's Avatar
re: A/C Blows Cold but car jerks & engine vibration & noises [solved?]
Could be overfilled
Old Jul 21, 2022
soupD2's Avatar
Ill bring it to the shop and see what they say. Thanks for the feedback
Old Jul 22, 2022
soupD2's Avatar
K, so decided not to head to the shop, got me one of those cheap a/c gauges and the a/c was in the green. Still let out some to see if there is any difference and after driving quite a bit while blasting the a/c, smell is not there, no noises other than blower, car jerks way less now and mostly on acceleration. Engine shake still does occur during idle but im guessing that can be solved by tightening the iacv or doing the idle relearn procedure. Ill probably try again soon and let out some more pressure but this look like success.
Old Jul 30, 2022
soupD2's Avatar
Okay so my belt has been squeaking for a while now so i went to check it and the tension bolt and a bolt holding the bracket to the alternator were both completely loose, belt was still decently tight somehow. Anyways I put em back in and tensioned it. Driving with A/C on is back to having issues, strange noises, super lag on throttle, etc. Was okay for the first 30 min drive but then when i got back on the freeway it started bugging. Still no problem with temp, blows really cold at all times.
Old Jul 30, 2022
Re: A/C Blows Cold but car jerks & engine vibration & noises
recheck the alternator again in a week or 100 mile driven.
that is a frequent ECU fried issue for the 7th gen cars
Old Jul 30, 2022
soupD2's Avatar
Okay, just so I understand better, how does the alternator and ecu connect to my problem?
Old Jul 30, 2022
not the problem you are having, warning you that loose alternator bolts can increase the amount of the problems you will have.
If you don't want good advice... i will stop trying to help if you don't want it
Old Jul 30, 2022
soupD2's Avatar
If you don't want good advice...i will stop
I noticed it was loose so I tightened it like it’s supposed to be, not expecting it to get loose again? I will still recheck like you said.
I never said your advice was bad was asking a question bc i like to learn and im far from an expert. Thanks for the reply
rystalcayyy
Nov 17, 2014 09:35 PM
kassa
Sep 12, 2014 10:14 PM
cobs00
Dec 30, 2011 09:13 AM
Ponyo
Nov 4, 2010 08:47 AM
babzog
16
May 5, 2010 10:27 AM
