Engine start problems Post issues with engine start here. Does not start, does not run, etc.
03 Civic ex will turn over, but will not start.
Old Jan 29, 2022
Iamjpg's Avatar
Iamjpg is an unknown quantity at this point
I was letting my car warm up before going to the store and it started sounding like it was drowning and then cuts off and would not start. We did a little inspecting and found out the valve gasket was bad, causing oil to get on the spark plugs. We fixed the valve gasket and replaced all four spark plugs. We checked for spark and everything was working as it should be. It still won’t start and I’m assuming it could be either the ECU (due to the rev limiting) or an oil solenoid maybe? I’m not sure what else to do or check for.
Old Jan 29, 2022
FRSam's Avatar
Click Here
Re: 03 Civic ex will turn over, but will not start.
You should have a check engine light. What’s it saying?
Old Jan 29, 2022
warning - if need (not saying it need) sensors, buy OEM - hondas are famous for not working nice with aftermarket sensors
moved thread to correct section, start reading the threads here. Plenty of possible causes.
morales_rafael
Jun 11, 2012 06:56 AM
95civic123
Nov 6, 2011 12:05 AM
keewee89
Nov 11, 2010 12:23 PM
TINOO
Aug 8, 2010 01:17 PM
civichxtreme
Apr 19, 2004 10:46 PM
