Engine start problems Post issues with engine start here. Does not start, does not run, etc.
Crank no start - ideas
Old Aug 2, 2021
LS2729's Avatar
LS2729 is an unknown quantity at this point
Purchased a 2005 Civic EX with 160k miles in March of this year. Probably a month after getting it, I started experiencing hard starts. I replaced the plugs, coil packs, air filter and everything was good. I had some other issues such as loose sensors, a missing connector for the output shaft speed sensor. Began having the hard start progressing to a no start. Replaced the crank position sensor and catalytic converter based on DTCs. Sometimes it would start, others it wouldn't. Fuel pump is working and fuel is making it to the cylinders. I gave in and took it to the shop that is supposed to be the best in the area with imports. I left a detailed account of everything I had done. They replaced the coil packs and tried to give it back when it barely started. I left it with them another week and they called saying that the Crank position sensor was the culprit. Two days later I took it back with same issues. They kept it a few more days and called with their diagnosis and a quote to fix. I had paid them $1200 by that point. Their diagnosis was a bad ignition switch and their quote to fix it was $1100. They told me that if I pushed the key in hard it would start. That was total BS. I declined their quote. I got it home and within a couple days it wouldn't start. As a last ditch effort, I replaced the plugs again. It instantly fired up and ran like a champ. After a week, hard start again. Another week, no start. I went through checking each coil for spark, etc. Plugs still look like new. Spark, fuel, air but no start. Since I really needed to go to work today, I replaced the plugs again. Fired right up. This morning it fired up perfectly. At noon today, hard start again. No codes whatsoever except for misfire code right after I got it back from the shop. I can't keep throwing money at the car. I'm about ready to use it for target practice. Anyone have any ideas?
Old Aug 2, 2021
Re: Crank no start - ideas
check cylinder compression
Old Aug 2, 2021
Colin42's Avatar
Aftermarket or OEM sensors?
Old Aug 3, 2021
LS2729's Avatar
I don't have the numbers, but the mechanic checked compression and told me it was good on all cylinders.
Old Aug 3, 2021
LS2729's Avatar
Originally Posted by Colin42
Aftermarket or OEM sensy?
OEM sensors
Old Aug 4, 2021
BrotatoChip's Avatar
Super Moderator
Once it starts does it running well? Is the hard start the only issue or are there issues when running too?
Old Aug 4, 2021
LS2729's Avatar
I noticed the ses light on after I put gas in. Can anyone interpret the freeze frame data for me? Anything stand out?
Old Aug 4, 2021
Wankenstein's Avatar
First, clean all engine and chassis grounds with a brass wire brush. Check starter connections. Clean battery post and cable terminals.
Check mechanical timing at the crank's timing gear and the cam's gear. Don't rely on the timing marks on the crank pulley and timing cover, as the belt may have skipped a tooth or two.
If the timing marks are in line then check valve clearances.
Old Aug 4, 2021
LS2729's Avatar
When it starts it runs good. I feel like there is a little more engine vibration than there should be. Gas mileage is about 30-32 mpg. When idling it has a "hickup" every few minutes.
Old Aug 6, 2021
LS2729's Avatar
It was hard starting again.. After eliminating all I know how to eliminate, for the third or fourth time, I changed the plugs again. Starts great but still sputters just a little. Just bought some NGK plugs to install in the morning. The ones I just installed aren't the best brand hence the NGK purchase.
Old Aug 7, 2021
Colin42's Avatar
Always use ngks in hondas
Old Aug 12, 2021
LS2729's Avatar
Anyone?
Old Aug 13, 2021
Super Moderator
None of those values are worrisome.
Old Aug 13, 2021
LS2729's Avatar
Thanks
Old Aug 14, 2021
Have you checked the engine and chassis ground connections yet?
Old Aug 14, 2021
LS2729's Avatar
Yes, I checked grounds at the beginning of this issue. Cleaned two and replaced one. No effect.
Old Aug 14, 2021
Verify mechanical timing or is it running well enough that it's not concerning?
I owned a 2007 Mazda 3 that would hard start after filling the fuel tank (not your car's issue) and the fix was to replace an evaporator hose that fed the evap solenoid. A common issue with that generation of Mazda engines. I've not experienced any evap issues with the Civic's I've owned or worked on but it's a possibility with any car that an evap issue can cause hard starts.
Old Aug 14, 2021
LS2729's Avatar
A knowledgeable Honda guy says it sounds like I need to replace the fuel pump assembly. He suggested having fuel pressure checked first though. Next on the list.
Old Aug 15, 2021
https://honda-tech.com/forums/honda-...ssure-2944675/
https://www.civicforums.com/forums/1...sure-test.html
Ted-04
Feb 5, 2019 01:52 PM
Civicbtch
Jul 29, 2018 04:13 PM
bdehn
Nov 28, 2017 06:05 PM
Kpike70
Nov 3, 2017 07:33 AM
Sethster99
Apr 6, 2013 12:51 PM
