Engine start problems Post issues with engine start here. Does not start, does not run, etc.
d17a2 won't start
Old Dec 15, 2015
Michael Irby's Avatar
Michael Irby is an unknown quantity at this point
d17a2 won't start
my car started fine and i drove 2 minutes down the street to the store.came out to leave and it would not start up.while trying to crank it.i can smell gas sorta like it's coming from the back half of the car.it seems like it will go to start up sometimes but doesn't.i pushed in the Schrade valve to see if any fuel comes out.nothing does not even a drop.
Old Dec 15, 2015
Re: d17a2 won't start
Compression?
Spark?
Fuel?
Plugs wet or dry?
Codes?
Because that was not a fuel line.
Old Dec 15, 2015
from what i remember, if you start and just move a little, our cars can flog.
wait some time and try again.
Old Dec 15, 2015
i have spark and i disconnected the fuel line at the rail and put the line in a jug.its pumping fuel to the rail when i turn the key.it has no codes the plugs on the passenger side have oil on the firing end.i took the valve cover off for some odd reason and its covered with water and oil underneath it.so could it be a bad warped head and blown head gasket and not enough compression to start it
Old Dec 15, 2015
i have spark
Ok, now do a compression test.
You mean the tubes had oil in them and it got on the plugs when you pulled them out?
If most of your trips are only 2 minutes long it may just be condensation.
It would not do this during a 2 minute drive unless the radiator were empty.
How about the compression test numbers?
Old Dec 16, 2015
mac25's Avatar
Dr Krieger of Modification
Just to make sure, you know what a valve cover is right (because some people use names they think are right on this site, but are not right which leads to diagnostic issues)?
In order to remove the valve cover you would have had to remove the timing belt cover,the coilpacks/ignition harness, and the five long bolt which bolt it to the head.
ps: was the oil on the sparking side of the spark plug (inside the combustion chamber) if so are you sure it was oil and not gas?
Old Dec 16, 2015
Valve cover comes off before the top timing cover.
Old Dec 16, 2015
mac25's Avatar
Oh right, I was trying to remember why I left it off but I did so so I could time it without removing the valve cover.
Old Dec 16, 2015
it has thick milky white resido under the valve cover and oil cap tried cranking it wouldn't start then open the radiator cap it made a hissing noise like when you open a 2 liter drink that's been shook up tried it again just to see then the coolant overflow tank hose popped off the radiator
Old Dec 16, 2015
Still sounds like simple condensation -- unless we can see more.
Pull out the dipstick: Does it oil look like clean oil, dark oil, or a chocolate milkshake?
How low is the radiator?
When is the last time anyone knew it was full?
Fill the radiator, pressurize to 15 PSI using a cooling system pressure tester, let it sit for a while, then crank the engine (spark plugs are still removed) and see if it blows water out of the cylinders when you crank it over.
If you find water has entered into any cylinder using this test, that's bad.
If it's extremely bad you might not even have to pressurize it, liquid may flow right into cylinders.
Note that a bad IAC gasket can also let coolant into the intake, which could enter cylinders eventually.
If the above check does not reveal leakage, then find the sticky thread about "overheating common causes reference" and read in the first post about ways to prove a head gasket combustion pressure leak.
Old Dec 17, 2015
it was chocolate milkshake on the dipstick and oil cap
Old Dec 20, 2015
If it has leaked coolant into the oil, I would expect to find a badly warped head.
Youngrob650
17
Oct 29, 2015 04:39 PM
Jake O
Oct 11, 2015 10:04 PM
68camerors
Sep 24, 2015 06:18 PM
kevfarr
Sep 18, 2015 02:28 PM
