Auto Transmission failures Post your issues with auto transmission failures here. 01-03 have had a high failure rates
Sorry if this is on here already. New here! Plz help..Auto Trans not engaging
Old Jan 21, 2024
Dubbs1221's Avatar
Dubbs1221 is an unknown quantity at this point
2002 civic Lx. I’m new here so I’m sorry if this is somewhere on the page. Was driving, came to stop and made a right turn. Car was driving fine then rpms went up and car wasn’t moving. So engine runs it just won’t engage in any gear. Called tow truck and had it towed back to house. I started the car so I could steer it down the tow truck to park it and for the hell of it I put it in reverse after getting off the truck and it engaged! Now every gear is engaging but I’m nervous to drive it on the road again just incase it happens again. No check engine light came on when it happened too. I can’t seem to figure out what the issue is. Could it possibly be a bad axle???
Old Jan 21, 2024
FRSam's Avatar
Click Here
Re: Sorry if this is on here already. New here! Plz help..Auto Trans not engaging
Plug in a code reader. I suspect you’ll have P0730 stored somewhere. That’s the death code for these transmissions and you’re showing the symptoms for it. Wouldn’t hurt to try draining and refilling the transmission fluid, but I suspect that’s a waste of time at this point.
Old Jan 21, 2024
Dubbs1221's Avatar
Don’t want to hear that lol. But I’ll plug my reader in when I get home and update. Thanks.
Old Jan 21, 2024
drain and fill 4 times while driving some in between, do not flush
it will eventually die, but the fluid change should help some
Old Jan 21, 2024
Dubbs1221's Avatar
Only code I get is P0171 (system too lean)(bank 1)
Kr1ngles
Apr 20, 2022 05:23 PM
Daniel Fountain
Transmission
Apr 5, 2021 06:30 AM
tbird8606
Nov 15, 2010 12:44 AM
someguy
Dec 10, 2005 01:35 AM
S2000man01
28
Apr 25, 2005 10:38 PM
