Auto Transmission failures Post your issues with auto transmission failures here. 01-03 have had a high failure rates
Revs high and barely moves
Old Mar 29, 2023
pres4ever's Avatar
pres4ever is an unknown quantity at this point
Hello guys I have an automatic with no check engine light and was recently driving home and came to a stop light. Once the light turned green I went to hit the gas and the car would rev to 3500-4000 rpm’s but would barely move struggling badly almost like a limp mode but still would kind of go. Kept on the gas and it would rev even higher barely making it to speed limit. I thankfully made it home and went to drive the next day and worked perfectly fine until about 2 days later it started to do the same exact thing. Car would rev super high and would barely make any movement. Noticed the car is leaking power steering fluid as my reservoir keeps getting drained within a day or 2. Need help asap. Could it be due to low power steering fluid?
Old Mar 29, 2023
Re: Revs high and barely moves
use search words transmission slipping
Old Mar 29, 2023
BrotatoChip's Avatar
Super Moderator
No. Have you checked other fluid levels? Like coolant? Check engine light on?
Old Mar 29, 2023
Colin42's Avatar
Trans is probably trashed. Try doing 3 drain and fills
Old Mar 29, 2023
pres4ever's Avatar
Yes I have checked all my other fluids and they are all good in the reservoir. There is no check engine light and nothing pops up when it does this weird slipping.
Old Mar 29, 2023
pres4ever's Avatar
It has 180,000 miles on it and i’m not sure if the fluid has ever been flushed. Draining it would make situations worse, right?
Old Mar 29, 2023
no, flushing finishes killing it
drain and fill 3 times is recommended honda procedure. It might extend the life a little bit
i moved to the section created for this problem, read around this section.
Yes, there is a section specific for auto trans failures in this generation cars, guess why?
Old Mar 29, 2023
Colin42's Avatar
​​​​​​​If it does the trans was already dead
Old Mar 30, 2023
Super Moderator
What year is the Civic?
I first thought the engine was way down on power but it does sound more like a slipping transmission.
Twistedballs
Exterior
Oct 22, 2019 12:59 PM
nobighero
Jun 12, 2014 07:33 PM
intrance9
39
May 26, 2011 01:40 AM
nova4dr_racer
15
Jul 8, 2005 08:39 PM
andoy
Jul 15, 2002 12:49 PM
