Ridiculous Water Accumulation
Rep Power: 0 Ridiculous Water Accumulation
Hey all.
My baby (96 Civic LX Sedan) accumulates water when it rains. Alot. Like a couple of cm.
Only on the front and back passenger side. The floor is swamped. But on the passenger side only !
What can it be ? Can I fix it myself ?
Thx alot
Thx alot
Rep Power: 788 Re: Ridiculous Water Accumulation
well you need to figure out where its coming in from. if you cant see it, then you may need to take out the carpet and stuff and use a garden hose to find where water is coming in from.
Rep Power: 0 Re: Ridiculous Water Accumulation
CHECK YOUR TAIL LIGHT GASKETS. Common for civics 96-2000. Ive had a 99 and now a 2000 and they both had leaky tail light gaskets.
Is the rear seat wet as well?
ive got a 96 DX, after it rains you can hear the bathtub in the spare tire well sloshing around. I would guess that I just need to replace the rubber sealer around the inside of the trunk lip though.
you have to get inside the trunk with a flashlight while its raining and see where water is coming from. usually its never the trunk seal.
mine was leaking bad from the rear window trim (the black piece that goes around the passenger rear window). there are clips that go into holes in the car body to hold it on, and water was getting in from there and slowly dripping down the frame into the trunk and finally to the bottom where the spare tire was. i put some rubber sealer goo into the hole and around the clip, and it never leaked again.
If you open the trunk and pull up the carpet on the left side there is a heat vent that feeds through to the outside. Thats where my leak was, when i got that nasty water in my trunk. I just used gasket maker and sealed it all up and hasnt done it in 6 months.
nice - thanks for the heads up. is that stuff fairly cheap?
After owning my 6th gen for less than two weeks this is the first issue I've encountered. I checked the tail lights and sure enough the drivers side tail light was leaking water into the trunk area. Last night I got in there and removed the tail light. The gasket was partially torn along the bottom. I applied a small amount of silicone sealant and hope it did the trick.
you bought new gaskets right? Im gonna slap you if you left the old gasket in there and just put some silicone on it
Tail light gaskets are common for 6th gen honda's, or atleast civic's. $20 a gasket, times 2 gaskets+ TOTAL B.S.
When I had my major leak I checked with the dealer about the gaskets. They said they never install new ones, they simply use silicone. My leaks were from both tail lights as well as the joint in the right rear of the car inside the trunk. The sealant had worn and torn over time and water was leaking in. I applied silicone over that as well. My daughters car is now dry as a bone. Thanks to Gearbox for his help when I was dealing with my flood!
He He, I guess reading that it seems as if I just gooped it up. No, I went down to the Honda dealer and picked up the gasket set. I replaced all of them but the drivers side didn't want to "seat" correctly so that's where the silicone came in. I applied a not so generous amount to the tail light bucket and let it set up before reinstalling the light.
Yes my rear seat is wet but only on drivers back seat, also my back; floor board on both side is very wet what would cause this?
rbreedi1
03-04-2019 08:23 AM
Gigga
28
12-17-2017 09:12 PM
kae
10-21-2012 03:30 PM
jiggaman2g
07-17-2006 01:13 PM
