Excessive Oil Leak
Old Dec 26, 2022
redstorm411's Avatar
redstorm411 is an unknown quantity at this point
Excessive Oil Leak
Looking for some coaching. This is my mom’s 2000 that has been a tank for her. She recently told me it’s dropping excessive oil in her driveway so I checked it out and it was over 2 quarts low. It appears to hemorrhaging in the lower front passenger side. I’m just getting familiar with this vehicle as it’s been a tank for mom and really hasn’t needed much over the years. I’ve attached a picture with the area it’s coming from. Cleaned it up this morning but it was difficult in the freeze we are in. I don’t think it’s the valve cover gasket. Any pointers to get me moving in the right direction are greatly appreciated.
Old Dec 26, 2022
Colin42's Avatar
Re: Excessive Oil Leak
Vtec solenoid can leak pretty bad on the back of the head and run down to there, or distributor oring.
Old Dec 26, 2022
Thanks. Both seem like good and easy maintenance work. Would you recommend OEM or is Advanced/AutoZone safe?
Old Dec 27, 2022
Colin42's Avatar
Oem is best
Old Dec 29, 2022
I did the Vtech Solenoid filter/gasket (side) and also did the distributor o-ring. No bueno! Any other suggestions. It continues to leak after the engine is turned off. Vehicle is parked with the nose slight downhill.
Old Dec 29, 2022
Colin42's Avatar
Somehow out of the headgasket maybe? Not very common
Old Apr 30, 2023
civicNorth's Avatar
civicNorth is an unknown quantity at this point
redstorm411 - did you find the source of the leak?
Old Apr 30, 2023
The Vtech solenoid up top seemed to the the problem.
sdx3812
Oct 21, 2022 06:24 AM
Pongo08
Sep 2, 2020 06:02 AM
fvckbg
Aug 19, 2016 10:17 PM
crg553
Jan 14, 2012 09:12 PM
tbroad1
Jul 5, 2010 07:05 AM
