1998 I need help with timing (PLEASE HELP)
Old Jun 8, 2021
AlejandroT's Avatar
AlejandroT is an unknown quantity at this point
Exclamation 1998 I need help with timing (PLEASE HELP)
My belt keeps slipping and I think its the tensioner but I bought a new one and mounted it correctly and sense Honda is the only one that make the spring I hade to go to a pick and pull to get it and it still didn't work and I'm stumped please help
Old Jun 9, 2021
Re: 1998 I need help with timing (PLEASE HELP)
isn't the cam gear slipping?
Check if the key is still there, or if the gear have damage and play
Old Jun 9, 2021
AlejandroT's Avatar
no I have the key and non of the gears have play so it has to be the tensioner but I am not sure but it could be the belt because my dad bought it but I check on advanced auto and it says it works and I am stumpted I've done timing more then 10 times not and it doesn't get tension and it slips when I try to start it
Old Jun 9, 2021
FRSam's Avatar
Click Here
Have you followed the correct procedure? I can’t remember exactly but you’re supposed to line up the timing, tension the belt, then loosen and crank like 6 teeth, then tighten again.
Old Jun 9, 2021
what is the reason you believe it's the timing?
what checks you did?
Old Jun 9, 2021
AlejandroT's Avatar
i put marks and tried to start it and checked and the belt slipped and also the belt doesn't get tight even with a new tensioner and spring
Old Jun 9, 2021
are you aware that the camshaft turns once while the crankshaft turns twice?
where did you put the marks?
you need to put the crankshaft in the right position before checking timing. Can't remember, cylinder 1 at TDC?
Old Jun 9, 2021
FRSam's Avatar
Click Here
I’ll quote this again
Old Jun 9, 2021
AlejandroT's Avatar
I don't know specifically but i have done something around that but not really ill try it though
g_villa187
Mar 4, 2012 10:41 AM
jordan101
Nov 18, 2011 11:32 AM
Speed9117
Jul 11, 2011 04:15 PM
cmeias
Apr 25, 2005 09:23 PM
nongv
Aug 14, 2003 06:32 PM
