help help help! rev limited at 3000 after timing belt
Old Jul 9, 2011
Speed9117's Avatar
Speed9117 will become famous soon enough
Help! I'm at a friends six hours from home with no internet. I'm on my phone so I can't really search.
We just did the timing belt and did a valve clearance adjustment and not everything together. It fired up and sounded great but when we went to test drive it is ECU rev limited at 3k. I think I saw a recent thread about this but can't find it. Please help.
Old Jul 10, 2011
Re: help help help! rev limited at 3000 after timing belt
get a code reader and hook it up first - your car is in limp mode, so codes should appear.
Old Jul 10, 2011
lazlong's Avatar
Most common causes are a pinched wire or you left a connector loose. Still need to check for codes though.
Old Jul 11, 2011
Speed9117's Avatar
Thanks for the advice. We got it figured out a couple hours after it happened. It turned out the crank sensor had been fouled when we drained the coolant so we blew it out with an air gun and plugged it back in and it was good to go.
EdGasket
May 25, 2015 01:06 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
Blaster30
Apr 22, 2015 12:21 PM
dano2005
Apr 14, 2015 01:58 AM
locozoko
Nov 8, 2001 06:33 PM
