Loss of Heat in cabin.
Old Feb 23, 2020
R0lm3l's Avatar
R0lm3l is an unknown quantity at this point
I'm at a loss right now, can't pin point where the problem may be so I'll run you guys through real quick of my situation.
I have a 1999 Civic EX EJ8, coupe.
I got it recently from my cousin; it sat for 2 years but started on the first try. I've been fixing it up so it is my daily right now.
I've had the car for about 2 months and up until last week I lost heat in the cabin; only blowing cold.
1. I checked my heater hoses, heat is going through both inlet to Heater core, and back out to the outlet.
2. No loss of fan speed whatsoever when I change fan speed. (Heater blower motor ok then?)
3. Temp sensor is working fine, haven't over heated.
4. Checked fuses and replaced them.
5. The heater blower Motor Relay works
Anything else I should check? I think the culprit is heater blower motor, heater blower resistor, or even just a coolant flush. Let me know your thoughts, thanks guys.
Old Feb 23, 2020
R0lm3l's Avatar
Re: Loss of Heat in cabin.
Also, checked coolant reservoir - full. Took off radiator cap and coolant is to the neck.
Old Feb 24, 2020
https://www.civicforums.com/forums/3...reference.html
looks like this applies to 6th gen too...
headgasket
Old Mar 7, 2020
emich's Avatar
emich is an unknown quantity at this point
Replace your coolant with water + 2 large spoons Disodium EDTA. Drive it for a month and it will take off the deposits from everything in contact. Beware the solution will freeze in cold weather.
Old Mar 7, 2020
Wankenstein's Avatar
Cabin heat is based on engine heat of which pressure is a part of.
Trapped air in coolant system, low coolant, blocked heater core (under dash), a thermostat stuck open, malfunctioning heater valve, heat and breached head gasket can all present as cabin air heat loss.
Start by bleeding air from coolant. Raise front end on Jack's, turn climate control to Max heat with fan off, let engine from cold start idle to operating temp with rad cap off (and optional spill-proof funnel) to bleed air bubbles until radiator fans engage (roughly 20-30 minutes). Add coolant mix as needed to keep radiator full and reservoir somewhere between min and max. Let engine cool and check radiator and reservoir levels..fill as needed.
Old Apr 1, 2020
R0lm3l's Avatar
Appreciate all your replies, I'll post what I find!
Ian Park
Nov 20, 2018 06:35 PM
Courtneyy
Air Conditioning
Mar 4, 2016 11:33 AM
CivicRen
Oct 18, 2011 09:21 PM
civiclover1991
Jan 4, 2011 02:38 AM
russo-r34
Oct 13, 2006 12:27 PM
