Electronics Post your questions about Electronics problems here!
Vtec code p1259
Old May 10, 2021
RoxanneCivic's Avatar
RoxanneCivic is an unknown quantity at this point
Vtec code p1259
Have a P1259 code.
oil pressure switch always metering 12v to ground from connector wire to ground. (metering the switch shows open circuit)
Activating vtec by applying +12 volt to pin on solenoid connector does not change the voltage reading at pressure switch. is this indicating bad oil pressure switch or vtec solenoid
Old May 10, 2021
Re: Vtec code p1259
if engine oil is low, it will happen.
check engine oil levels
Old May 10, 2021
Re: Vtec code p1259
Oil just changed. Thought that might be the problem. oil was quite dirty.
Old May 10, 2021
Re: Vtec code p1259
then it is electrical. unless they did not put enough oil there. or some debri got into the oil passages
Old May 10, 2021
Re: Vtec code p1259
Originally Posted by RoxanneCivic
Have a P1259 code.
Have a "CheckEngine" Light on.
if it is a bad pressure switch will it still show this light on or "Oil" light
Teino
Sep 16, 2020 01:33 PM
speediq99
Mar 21, 2020 06:35 PM
2kej6
May 13, 2017 01:35 PM
redlion4
Jul 10, 2012 11:10 AM
mwebb
May 10, 2012 06:41 AM
