2005 Civic HX ECU
Old Oct 23, 2022
kmj4458's Avatar
kmj4458 is an unknown quantity at this point
2005 Civic HX ECU
I have been told I need a new ECU. It has an item number 37820-PMP-130. Cannot find this exact number anywhere. Does a replacement have to match exactly to function? Or can a similar number be somehow reprogrammed? Started having intermittent issues: No click, start or dashboard lights whatsoever, crank and dashboard lights but no start, idle problems, engine stopping for no reason, loss of power. These are all intermittent, much of the time the car operates normally. Any suggestions appreciated. Thanks.
Old Oct 23, 2022
FRSam's Avatar
Click Here
Re: 2005 Civic HX ECU
Don't quote me on this because it's nothing more than an educated guess, but I would assume that you can put another manual ECU on it, but it will lose it's "HX" qualities of increased fuel economy, and assume the normal role of an LX or DX. Don't take this as completely correct advice, but if you have a local junkyard and can find a functional ECU dirt cheap, I think it might be worth looking into.
Old Oct 24, 2022
I think the HX have the VTEC, D17A6? - if so an EX ECU could work, not sure.
If you use from a DX/LX, the VTEC will not work
Edit:
the HX had the D17A6
https://en.wikipedia.org/wiki/Honda_...nth_generation)
D17A6
  • VTEC-E
  • Found in:
    • 2001–2005 Honda Civic HX
      • Displacement : 1,668 cc (101.8 cu in)
      • Bore and Stroke : 75 mm × 94.4 mm (2.95 in × 3.72 in)
      • Compression : 9.9:1
      • Power : 117 hp (87 kW; 119 PS) at 6,100 rpm[20]
      • Torque : 111 lb⋅ft (150 N⋅m) at 4,500 rpm[20]
      • Valvetrain : SOHC VTEC-E Lean Burn (4 valves per cylinder)
      • VTEC Switchover : 2,300 rpm
      • Fuel Control : OBD-2 MPFI
photiost
ECU Fried
Nov 22, 2019 03:41 PM
MariV
Jul 12, 2019 02:56 PM
redrocket87
Mar 4, 2018 07:39 PM
sbblumhof
May 25, 2010 01:57 PM
civichxtreme
Apr 29, 2004 09:37 PM
