2003 Honda Civic EX Loses Power at 3800 RPM
Old Apr 29, 2014
dmana12000's Avatar
dmana12000 is an unknown quantity at this point
I have a 2003 Honda Civic EX 4 cyl with no mods and I have a problem my mechanic can't seem to solve. I was going down the road and accelerated to 3800 RPM and I lost power and had to back off to continue going. The check engine light came on and it showed code for Crank Sensor.
We replaced the sensor and it had done nothing. You can be in any gear and it is fine but as soon as I touch 3800 rpm it quits.
I had a freind say, maybe fuel filter it plugged, maybe it is a bad distributor.
Any ideas.
Old Apr 29, 2014
Re: 2003 Honda Civic EX Loses Power at 3800 RPM
What is the code number?
Terminal corrosion in the CKP connector could be an issue.
Replace your mechanic.
There is info available in any decent service information system about how to troubleshoot for almost any code.
This might be a decent guess if you didn't have a glaring CEL/code problem staring you in the face.
Fuel filter problems are easy to test for if one has the correct tools and knowledge.....
However, someone needs to address and fix the CEL problem FIRST.
Try to replace the distributor.
Go ahead.
I'll wait right here.
Old Apr 29, 2014
check engine oil levels while at it
Old Apr 30, 2014
dmana12000's Avatar
2003 Civic EX complete power loss at 3800 RPM
Thank you all for the advice yesterday. mechanic replaced. Starting from square 1
Last edited by dmana12000; Apr 30, 2014 at 12:10 PM. Reason: I am new to the forum and made a duplicate post
Old Apr 30, 2014
dmana12000's Avatar
Thank you all very much. Looks like a mechanic replacement is in order!! All of your advice is invaluable. How much do I owe you and where do I send the check
Old Apr 30, 2014
one millions for each of us :P
Old May 1, 2014
dmana12000's Avatar
New guy I brought this to is telling me from the research he has done the first step is to replace the entire distributor. I called a few junk yards and the best deal I have found is $375 out of a civic that was totalled at 107K.
Anyone have any other ideas on a good spot to try to find a distributior for a 2003 4 Cyl Civic EX?
Old May 1, 2014
http://www.car-part.com/
but...
you do know that your car does not have distributors, right?
that's what ezone was meaning above...
Old May 1, 2014
You are in the USA, you have a 2003 Civic EX 1.7 liter engine, originally sold in the USA.
The car does not have a distributor.
Your mechanic is still broken.
So are the junkyards, if they have distributors for a 2003 Civic.
Try to find a mechanic that specializes in FIXING cars, instead of finding the ones that work on cars and fire the parts cannon repeatedly until you run out of money.
You never bothered to post the trouble code number either.
Old Oct 12, 2022
AJohansen's Avatar
AJohansen is an unknown quantity at this point
@dmana12000 were you able to identify the correct problem and get it resolved? I'm having the exact same issue with my 2003 Civic. Mechanics are stumped to the underlying issue and keep rereplacing the crank shaft sensors to address the error code after every breakdown.
Old Oct 13, 2022
Colin42's Avatar
Going to guess you're using aftermarket sensors
Old Oct 13, 2022
AJohansen's Avatar
​​​​​​They're new sensors each time and I trust the mechanic purchased the best option he was able to find, because he's bought superior quality long-lasting parts for other repairs in the past. He's done everything he knows to fix the issue. But I know the car is still not driving with the same power I'm used to, and if I push it, like to maintain highway speed while going uphill, it will have another bang and start acting like there's no fuel getting to the engine intermittently. And have the same engine light come on and throw the same sensor code again. There's something else going on before that sensor goes.
I've spent too much money on getting it fixed multiple times so looking to learn from someone who's seen and resolved this issue before.
Old Oct 13, 2022
ask him if they were Denso or NTK? These are the OEM ones. Have him checked the wiring continuity? old wiring is brittle
Old Oct 13, 2022
AJohansen's Avatar
Confirmed with the mechanic. He used OEM sensors. Car also had the check engine light come on today though it kept driving without incident. P0171.
Planning to take it to a different garage that can put it on a jig and run full diagnostics at high revs. Fingers crossed they find the real problem.
Old Oct 13, 2022
Colin42's Avatar
That code can cause issues with the engine running properly.
Old Oct 14, 2022
crajnai's Avatar
7th Gen Victim
crajnai has a spectacular aura aboutcrajnai has a spectacular aura about
Check the vTEC solenoid wire. I forgot to plug mine in and around 3800 was the max it would go.
Old Oct 14, 2022
BrotatoChip's Avatar
Super Moderator
P0171: Fuel system too lean. Meaning the ECU thinks it's not getting enough fuel. Check fuel pressure, injectors, primary O2 sensor.
Old Oct 25, 2022
Irishlumberjack's Avatar
Honda guru
Irishlumberjack is an unknown quantity at this point
I had a similar issue with my 02 EX. It threw the same code and I almost bought and replaced the CRS but I heard a little trick to test what sensor is faulty. I was watching YouTube and the mechanic said that you can take the harness off the CRS and it will put the motor into limp mode, meaning the it won’t rev above past 4K but if it doesn’t die when you take that off then it’s the TDC sensor or the CPS whatever ya wanna call it. Mine ran alright till it got warm then the problem was right back! I bought and installed the new OEM TDC sensor and it was fixed just like that. I’d do the can sensor first, it’s the easier one to replace. I watched a YouTube video and did the repair and cleaned the EGR and put a new PCV valve in like and hour.
PomerJoN
Jun 5, 2022 12:08 AM
uspic2
Aug 2, 2021 10:26 AM
civic_civilian
Sep 26, 2013 09:35 PM
x3nzox
Mar 7, 2013 08:25 PM
IRPancake
Oct 8, 2009 12:21 PM
