Transmission fill bolt vs. Oil drain bolt: same?
Old 10-05-2018
Dziri's Avatar
Dziri is an unknown quantity at this point
Hello, first post:-)
I was about to change the transmission fluid on my 2003 Civic EX (stick shift) and noticed that the head of the fill bolt was stripped, so obviously I didn't go ahead with the fluid flush since I'm going to need a new bolt first.
On the outside, this bolt appears to look just like the oil pan drain bolt (17mm) but I couldn't find any info on the shank length and the thread size.
Could anybody please confirm that these two bolts are (or aren't) the same?
Thanks a lot:-)
P.S: this is the oil drain bolt, which was also stripped last time I changed the oil. Looks like some mechanics use impact guns to tighten oil drain bolts, which is also probably what he used on the transmission fill bolt. From now on, my car will never see the shop for oil and transmission fluid changes.
Stripped oil pan drain bolt
Old 10-05-2018
Dziri's Avatar
Re: Transmission fill bolt vs. Oil drain bolt: same?
Specs of the oil drain bolt:
Old 10-05-2018
Trans drainplug is PROBABLY also 14 x 1.5
Fill plug is listed as 20mm
Either order from a dealer or scrounge some from a salvage yard?
Get new sealing washers for both as well!
https://www.hondaautomotiveparts.com...ission-housing
Old 10-05-2018
Slumpertcivic's Avatar
Not saying they weren’t also using a impact gun, but by those marks seem like they were definately using SAE tools instead of metric....
Prolly what kept the impact gun from ripping the threads out..
Old 10-05-2018
Oil change by Mr. Goodpliers
Old 10-06-2018
Dziri's Avatar
Thanks a lot, ezone.
The link you provided helped me find a lot of info about that bolt (like in this Honda parts website)
Now at least I know it's Honda part# 92800-20000.
And since it's a 20mm bolt, it cannot be the same as the oil drain bolt (14mm) because the oil drain bolt thread spec is M14-1.5.
So therefore the transmission fill bolt must be M20-1.5 (number after the "M" is the diameter of the bolt, not its length). The "1.5" (called "thread pitch") is the distance in mm between each thread. This vid explains those numbers:
So now I'll have to research two more pieces of info: length of bolt and thread pitch.
The thread pitch is probably the same as the oil drain bolt (i.e, 1.5) but I can't be sure about the length, though I don't think the length would really matter in this case if it was a couple of millimeters longer or shorter.
Anyway, I'm just being **** about this stuff, lol. Like you said, I should just go to a Honda dealer and see if they have the darn bolt.
I'm just glad I was "smart enough" to check the fill bolt first, before loosening the drain bolt, lol.
Thanks again.
Honda450RCivic
03-12-2008 08:10 PM
herroherror
25
05-20-2007 07:49 PM
Taffy
17
02-22-2006 03:17 PM
mrDFWmechanic
22
12-14-2005 12:02 AM
speedracersong
12-30-2003 10:39 PM
Quick Reply: Transmission fill bolt vs. Oil drain bolt: same?
