Oil Drain Bolt (Can't get it off)
Old Feb 16, 2006
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
Man I always took my car to the dealer to get oil changes, but today I wanted to try to do it myself and when I was attempting to get the drain bolt off I couldn't because they torqued it on so tight. Oh yeah they didn't use a crush washer either so it is metal on metal contact. I was seriously trying for like 30 min. to get it off. I am going to borrow one of my buddy's cordless impact guns to see if I can't get it off that way. You think that will hurt the oil pan at all?
Old Feb 16, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
cordless impact? wtf?
Old Feb 16, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Think reverse hammer drill... they're not overly powerful.
The torque spec is like 27 ft lbs.... its not a lot. Are you sure you're loosening it and not tightening it?
It shouldn't be that hard to get off.
Old Feb 16, 2006
streetglower's Avatar
just put a 17MM wrench on it and use a rubber mallet and hit the wrench to loosen it. It really shouldnt be that tight. And as boilermaker said, are you sure you arent accidentally trying to tighten it. righty tighty, lefty loosey. the bolt really cant be that tight. that bolt can only be tight so much before it will strip. And it isnt that much. I have first hand experience on that.
Old Feb 16, 2006
Taffy's Avatar
LOL! Yes guys I know I am trying to loosen it, (Counter Clockwise). So the socket size is 17mm? ok. I think the bastard who put it on last used one of those impact wrenches and tightened the bastard all the way down. If I get it off I'm gonna chuck it through the Honda dealership window. Those bastards
Old Feb 16, 2006
just go to the dealer and be like "wtf!? fix it for free.. or else.." or something along the lines of that..
its their fault for torquing that thing down like a bitch as opposed to the 27ft-lbs..
Old Feb 16, 2006
dealers have a habit of doing it really tight.
Old Feb 17, 2006
DDragon7's Avatar
Yeah, last time I changed my oil it was biatch to take it off, I ended up stripping one side the the bolt and I couldnt get the filter off.
Old Feb 17, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
that's why I always DIY my oil changes ;P
honda stealership techs always have a habit of using their impact with everything... lug nuts especially.
Old Feb 17, 2006
guys, the dealer isnt going to use an impact to put on the drain bolt. If they did, it would imediately strip. And probably crack the pan. again, it doesnt take much for that bolt to strip. it isnt like you can torque it down to 100 ft. lbs. Besides, I have never seen any tech ever use a impact to put a drain bolt on. Doesnt mean it doesnt happen though.
Old Feb 17, 2006
Taffy's Avatar
WooT! I just finished changing my oil for the first time!
I had one one my auto tech buddies look at the bolt and he turned it right away, he was like "There's nothing wrong with this." Pretty much made me look like a dumbass. Well he loosened it a little so when I got home I unbolted it rather easily. Now the Filter was a bitch to get off. But after 30 min. I finished the oil change. Nothing like the satisfaction of doing it yourself.
(Oh yeah, and I was tounge-lashed at for the idea of using an impact wrench to loosen it, my friend was like that's the dumbest thing you could do.)
Thanks for the help guys!
Old Feb 18, 2006
its not uncommon for a tech to use a air ratchet to remove a drain bolt, but they shouldnt use it to reinstall it. an air ratchet operates at a much lower torque then a impact so it would be ok to use.
Old Feb 18, 2006
Synapz's Avatar
Synapz is an unknown quantity at this point
i got the drain bolt off easily... the most trouble was with the oil filter, it was just impossible to take it off by hand... had to hammer in a screwdriver to leverage it out
Old Feb 20, 2006
XSRCivic's Avatar
i only use fram oil filters for that reason.
Old Feb 20, 2006
jerseydetailer's Avatar
jerseydetailer has a little shameless behaviour in the past
i mean i know ppl do this but they do sell tools to get off your oil filter
http://www.sears.com/sr/javasr/produ...cegjdghldghf.0
and make sure to put oil on the oil filter seal
Old Feb 21, 2006
Civicman1988's Avatar
try to put some Pb blaster on it. You can get ti at autozone just about everyplace that has automotive has it. Well spray it on there let it sit for about 15 minutes and then try to take it off. I just did struts on my saturn and i used it and the bolts have been threw 10 years of salt first try they came off. Good luck
Old Feb 22, 2006
dru106's Avatar
ThE CoRRupToR
lol, the best way is to buy a long handle ratchet with a 17mm 6 point socket and for sure it will come out east everytime.......
Old Feb 22, 2006
yup i agree...its what 17mm i think anyways..get a 6point socket (not 12 point) 1/2 inch drive and a 1/2 drive craftsman t-bar....aka breaker bar...not the ratchet ..put it like this, to remove lugs i use a 19mm socket 1/2 drive with a 1/2 drive tbar and they easily removed my brother overtorqued lug nuts with one hand
LionSpratt
Jan 29, 2017 11:07 PM
RIPSAW
Nov 6, 2015 04:36 AM
stvpagn
Jul 9, 2015 09:59 PM
trellex
Electrical
Jul 9, 2015 12:01 PM
Grey
16
Jan 27, 2002 11:34 PM
