Weird noise need help
Old Jun 5, 2018
justinakaparker's Avatar
justinakaparker is an unknown quantity at this point
Exclamation Weird noise need help
Ok. so i was teaching my girlfriend how to drive a stick and she popped my clutch and knocked it dead. she gave up after one try, but needless to say when i went to crank it my horn goes off now by its self when its under 1000 rpm. i know its bad wiring has to be but which wire could it be? ill take any advice i can, real annoying to keep having to rev up at stop signs, red lights, drive thru everywhere. or how to rev my car up to 1000 and stay.
Old Jun 5, 2018
GolNat's Avatar
Prelude Owner
Re: Weird noise need help
Pull the fuse for the horn for now.
So if its just sitting there idling the horn is going off and then when you increase the RPM of the engine past 1000 the horn stops?
Old Jun 5, 2018
tried that already. still goes off and yeah its like the lower my rpms the louder the horn at like 900 rpm(guess) is faint horn and at 600 (guess) its loud af and it goes with my idle but soon as i touch the gas and it revs over 1000 horn stops
Old Jun 5, 2018
do you know a way to rev up my chevy s10 i just have to twist a screw
Old Jun 5, 2018
GolNat's Avatar
Prelude Owner
Pull power wire off of horn for now.
What year and model do you have?
I am not sure how either of those 2 things are connected.
Old Jun 5, 2018
I disn't think they was connected either but it's a 04 lx with a 1.7 base
Old Jun 5, 2018
Was the drivers airbag recall just done, now the horn pad is too sensitive or it honks on bumps, or just vibrations?
Old Jun 5, 2018
Just checked no recall
Old Jun 6, 2018
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
To disable the horn temporarily while you figure out the problem is to remove the horn relay. It is relay B in the under-hood fuse/relay box http://troubleshootmyvehicle.com/hon...-hood-fuse-box
DeX
Sep 12, 2013 01:10 PM
darkhonda2k2
Feb 26, 2007 01:19 AM
lovemyhybrid
Oct 15, 2004 01:37 AM
astr033
Jun 5, 2003 07:02 AM
LuvDatCivic
Sep 27, 2002 01:16 PM
