Need help with P1259 code
Old Mar 26, 2018
  #31
03_EM2's Avatar
03_EM2 is an unknown quantity at this point
Re: Need help with P1259 code
Originally Posted by NDNV
Is this hose ready to burst? Looks bad to me from this photo...
I also thought the same, gonna pick a new one up soon just to be safe.
Old Mar 26, 2018
  #32
03_EM2's Avatar
Originally Posted by Slumpertcivic
That bolt hole looks like where the support bracket that holds your ac and power steering hose would connect if your car still had the bracket..
But is this bracket necessary? If it’s not needed then I’m not gonna sweat it. The hoses seem fine and I can’t really see a need to get it if it’s doing fine for now.
Old Mar 26, 2018
  #33
03_EM2's Avatar
Originally Posted by ezone
Also...PCM won't allow VTEC to operate unless it's in gear with wheels turning
If this is the case then how do I check with my multimeter? Remove my hood and tell my buddy to hold on for the ride? lmao. I don’t really wanna go buy wire to run into the cabin
Old Mar 26, 2018
  #34
Colin42's Avatar
tape it to the windshield?
extra long leads run through the window or door?
Old Mar 30, 2018
  #35
03_EM2's Avatar
Checked cam plug and vtec solenoid for the cause of the leaking yesterday, didn’t see any oil around the cam plug nor did I see any around the solenoid gasket area. Leak seems to be coming from lower on the engine. My buddy still seems determined that it’s my rear main seal, still not sure if I agree with him but there does seem to be a lot more oil and residue where the engine and trans come together. Gonna clean the engine up this afternoon with some brake cleaner and degreaser then gonna do the oil pan gasket Sunday. Will try to look on the underside for the leak.
Old Mar 30, 2018
  #36
03_EM2's Avatar
**Also forgot to add that I’ll be checking for the “missing bolt” under the valve cover and redoing the valve cover gasket.
Old Mar 30, 2018
  #37
Long wires run through a window to the inside of the car so you can set it on the dash
or
Jack the wheels off the ground (safety=jack stands) and run it in 1st gear
Old Apr 3, 2018
  #38
03_EM2's Avatar
Ok so still didn’t get anything done with the P1259 issues. I’m a terrible procrastinator and it’ll probably hurt me in the end. I did plug in a code reader my uncle has, it’s a FIXD Bluetooth code reader. I’ve included a screenshot of the freeze frame data that it showed. Code P0401 changed to P1491, anyone else thing I’ve killed my EGR valve?
Old Apr 3, 2018
  #39
P1491 and P0401 are both valid codes, but if one reader says one thing and another does not, then at least one reader must be lying to you....which ain't good if you're sent down the wrong diagnostic path.
P0401 is low flow
P1491 is insufficient lift (opening)
Also, I don't see any freeze frame data. Just codes.
Old Apr 4, 2018
  #40
03_EM2's Avatar
P0401 is low flow
Yeah it’s not the best reader but it was all that was on hand at the time, that’s the only logs it will show. Gonna go to advanced auto today and have them read the codes and I’ll get pics from there. Until then I’m uncertain on which code to trust.
Old Apr 4, 2018
  #41
03_EM2's Avatar
Called a shop this morning waiting for a call back to describe my situation and hopefully get a quote. It’s not the route I wanted to go but work is starting to pick up more and I just can’t get the time to worry with it myself. Going to tell them the codes I have and also going to mention the oil leak (which seems to be getting worse).
circuitt
18
Mar 28, 2012 06:10 PM
WKD DRGN
Apr 5, 2011 09:42 PM
fyrfytrryn
Oct 2, 2010 12:19 AM
lunakim
Mar 13, 2010 04:03 PM
business247
Aug 15, 2007 06:27 PM
