Driver door does not lock when it is open.
Old Sep 6, 2016
SightScout's Avatar
SightScout is an unknown quantity at this point
Hi so my drivers door was replaced and the power lock works when the doors are closed(except the passenger door lock doesn't respond to it. I have to lock and unlock that one manually.) I am posting because my driver side door will not lock when the door is open. Basically I cannot lock the car unless I open the back door and lock it when the driver side door is shut. (The lock cylinder on the driver door needs to be recoded for my key since it was replaced.) What can cause the door lock not to work when the door is open? Should I just invest in a alarm system so I don't have to recode the door lock and wire the passenger door lock?
Old Sep 6, 2016
GusBuz's Avatar
GusBuz is a jewel in the roughGusBuz is a jewel in the roughGusBuz is a jewel in the rough
Re: Driver door does not lock when it is open.
It sounds like its doing what its supposed to. The driver door won't lock unless it is closed. Its made so people wont lock the keys inside the car or at least try not to. Heres a thread talking about it. https://www.civicforums.com/forums/2...when-open.html
Old Sep 6, 2016
mikey1's Avatar
with the driver door open, you need to hold the release on the INSIDE of the door (like you are trying to open the door) while you push the door lock down
Old Sep 6, 2016
SightScout's Avatar
ok thanks that answered my question.
I just posted because since the door was replaced I thought it might have been faulty.
Old Sep 6, 2016
Or pull and hold the OUTSIDE release handle before locking or unlocking.
brivn
Dec 16, 2015 09:11 AM
mgcivicdriver
Engine start problems
16
Dec 10, 2015 11:58 PM
steve6
Nov 22, 2015 08:18 PM
Fturn97
Electronics
Oct 22, 2015 09:08 AM
Macko
Exterior
Nov 19, 2001 10:34 PM
