DRL Problem - dim passenger headlight
Old Jun 4, 2016
519city91's Avatar
519city91 is an unknown quantity at this point
I have a 2003 Honda Civic Lx Coupe and one day I noticed my car was making a buzzing sound behind the glove box and I looked online and it seemed like I found a solution which was to solder the drl module behind the trunk release lever. I resoldered the drl module and plugged it in which got rid of the buzzimg however, the passenger side headlight remains very dim when switched to lowbeam or hibeam.
I tried swapping bulbs, tried resoldering the drl module behind the trunk release, took apart the combination switch on the steering wheel which looked fine and I tried replacing the drl relay behind the glove box also (I have 2 Gray modules 1 looks old and a new one was with the car when I got it, inside a oem Honda wrapper, ive tried switching between those and still nothing), I checked and rechecked all fuses which seem fine and my passenger headlight is still very dim, I also noticed my parking light on the passenger side flickers...If anyone has any solution or knows of a fix please let me know this has been driving me nuts, thanks in advance!
Old Jun 4, 2016
CraigW's Avatar
Re: DRL Problem - dim passenger headlight
Does it work ok in drl mode on that side ??
Since both and low & high beam are affected....almost like a poor grounding path for that bulb somewhere in it's complex path.
The marker light should be separate unless there is a common connector/harness that is causing both dim headlight, and marker flicker.
Move around some close to the bulbs harnesses and connectors and look for changes while on.
Old Jun 14, 2016
519city91's Avatar
I tried looking for a problem, the connector to the bulb has some kind of grease/gunk inside the terminal connector area. I tried adding a ground what I believe is the ground wire but that didn't do anything either. Is there any way to bypass the ground or make my own ground somehow? I'm not sure how the system works exactly and at this point i'm willing to try anything. It's so infuriating because it's just dim and moving it around doesn't change anything. I looked at the wiring and it looks like someone added a connector for a different type of headlight but I couldn't find any abnormally spliced wires or anything, any ideas are appreciated thanks.
Old Jun 15, 2016
CraigW's Avatar
https://www.civicforums.com/forums/3...l-problem.html
This thread has the w/drl schematics, and one side is working correctly.
You could make measurements from the working side. Whack that drl module case with a medium screwdriver handle WHILE watching for changes in brightness from problem side.
OptimisticWay
Jan 3, 2016 07:54 AM
trv020
Oct 28, 2015 10:37 PM
Hnoob
Oct 22, 2015 07:38 AM
shriketheavatar
Oct 20, 2015 08:31 PM
nymbus2k
Nov 11, 2001 08:53 PM
