Pulley moved while changing harmonic balancer
Old Jan 11, 2016
EX_Rubicon's Avatar
EX_Rubicon is an unknown quantity at this point
Attempting to replace the harmonic balancer/crank pulley. While trying to loosen the bolt the crank socket tool popped out and the pulley moved slightly. from what I know this happening moves the valves, could they possibly be open in the cylinders now? Or would turning on the engine damage things. The pulley only moved maybe an inch but I dont want to risk anything.
Any help is appreciated. Thanks
Old Jan 11, 2016
Mad Dog Tannen's Avatar
Re: Pulley moved while changing harmonic balancer
If you never disconnected the timing belt, then you are fine.
If the belt was off then you have more work ahead of you. don't loose the small metal key that aligns the pulley when you remove/replace it.
Old Jan 11, 2016
EX_Rubicon's Avatar
Only belts that are off are power steering and AC/alt belts. Haven't opened up or touched the timing belt at all. So I'm all set, if I change this pulley and put the belts back on starting will be fine?
Old Jan 11, 2016
Make sure to torque it to spec and tension the belts properly, and then yes it should be fine.
35
Oct 31, 2015 10:06 PM
EdGasket
20
Oct 29, 2015 11:30 AM
damahark
Oct 28, 2015 08:11 AM
pnamajck
Oct 27, 2015 07:09 AM
98mxz500
Oct 22, 2015 10:20 PM
