Brake Pedal Squeak
Old Dec 27, 2015
Kennykenny's Avatar
Kennykenny is an unknown quantity at this point
Brake Pedal Squeak
I have a 2005 Civic LX 4 door. The car has a squeak coming from the break pedal area(I believe). When the pedal is pushed down and let go, while stationary, there is a squeak. The squeak does not occur when the car is moving at a decent amount of speed and the pedal is pushed in to slow the car down. If the car is moving at a slow speed, such as slowing down gradually and coming to a stop, such as at stop light, there is a squeak.
I have lubricated the top of the pedal bracket but no change thus figuring that it is not coming from that area.
Ideas? Thanks!
Old Dec 27, 2015
Re: Brake Pedal Squeak
Stick your head out the window and see if it is coming from the rear brakes.
Have someone on the outside of the car listen too.
Old Dec 28, 2015
CraigW's Avatar
See if working the hand brake on/off will produce it.
If so it is where the bottom [ portion of the shoes contact the backing plate.
Lube in that area of the backing plate to resolve.
Old Dec 28, 2015
Kennykenny's Avatar
There is a bit of a squeak when putting the hand brake down, not as drastic as when pushing down the foot pedal though.
When you say the shoes contacting the backing plate, assuming that means the backing plate is the back side of the rotor that the pads are grabbing a hold of on the front brakes?
Thanks for the suggestion.
Old Dec 28, 2015
Kennykenny's Avatar
I guess that I wasn't reading clearly when reading your response, you said shoes which meant the rear drum brakes right? So take the drum off and clean and lube that area?
Old Dec 28, 2015
Each brake shoe has 3 flat areas where it contacts the steel backing plate. The backing plate has a corresponding number of flat areas where each shoe makes contact.
3 per shoe
6 per side
12 total
I use moly grease for these
Google image search, there's a ton of stuff like this:
Old Dec 29, 2015
CraigW's Avatar
When I did my 05 it was a simple fix, no disassembly required. (think it is the lower ones)
And yes, it squeaks on brake pedal release, or hand brake release.
Old Dec 29, 2015
Kennykenny's Avatar
Thanks for this. Can you or someone provide information on how to put moly grease on the contact points without removing the shoes? A video would be great if this is possible to provide. I assume that this is not hard to do but seeing it done first would be very beneficial.
Thanks again.
Old Dec 30, 2015
CraigW's Avatar
Yes, A good flashlight and something to dab the lube to the backing plate.
A chopstick or dowel, stiff wire. It only takes a small amount once you locate thee area it goes.
Old Jan 1, 2016
Kennykenny's Avatar
Without having the knowledge or experience of working with brakes before, do the shoes have play that you can move them away(with a screwdriver or something) from the backing plate to give room to dab the grease on? Thanks!
Old Jan 2, 2016
CraigW's Avatar
I would not try to move them out, and would not work them much without drums in place.
Believe the culprit to be the lower [ that makes the noise, and it is easily seen and iirc, you can see the area of the backing plate where they ride. try to get lube onto each side of them L & R then put the drums back on and work the hand brake several times to distribute lube.
Old Jan 2, 2016
Kennykenny's Avatar
Thanks for the responses. Will give it a shot and let you know.
Old Jan 2, 2016
lowlife9's Avatar
my guess is its the return springs in the rear drums those always make noises on hondas. clean and lube them.
Old Jan 2, 2016
Kennykenny's Avatar
Thanks. Do you lube the springs with the same moly grease that has been mentioned earlier to lube the contact points. Is it a good idea to spray down all of the components with brake cleaner once I take off the drum prior to taking lubing the contact points?
Old Jan 3, 2016
Wankenstein's Avatar
Did you grease the return spring?
Shown in generic internet pic (not circled in white):
alinaray
18
Aug 24, 2015 01:04 PM
Uan
Aug 23, 2015 03:03 AM
2005seTO
Aug 18, 2015 12:45 PM
NukeSilo
Nov 4, 2001 09:37 PM
Markias
Detailing
Nov 4, 2001 05:15 PM
