DRL On
Old Oct 29, 2015
mikey1's Avatar
DRL On
a few weeks ago when i started my car, the DRL light came on the dash, which has never happened before, unless my hand brake is on,
i never use my hand brake, really only when i service the vehicle,
so with the car idling and still in park, i engaged the hand brake and released it a few times, but the DRL still stayed on, i drove away and the light went off by itself after about 2 mins,
this happened once again a few days later, but has not happened now in over a week,
no service has been done to the car during this time, kinda strange, anything to look for or be concerned about?
Old Oct 29, 2015
CraigW's Avatar
Re: DRL On
8th gen ??
DRL on the dash is to indicate a problem with the system.
Next time look to see if both are lit when in DRL mode (or high beams) The system still lights the working sides bulb.
Old Oct 29, 2015
mikey1's Avatar
Re: DRL On
7th gen
2005
Old Oct 29, 2015
CraigW's Avatar
Re: DRL On
Canada model.
Yes, check up front next time it comes on to see if both are lighting. (intermittent connection)
Old Dec 9, 2015
mikey1's Avatar
Re: DRL On
Originally Posted by CraigW
Canada model.
its been happening now maybe once every 7-10 days always after i start the engine,
when the DRL light is on, the headlights are completely off,
things i have noticed.....
when the DRL is on, if i turn my headlights on, and then turn them off, the DRL light goes out and the DRL's work as normal,
also,
this morning i started it up and the DRL light was on, no headlights at all, i opened and closed my drivers door, and when i closed the door the DRL light went out and the DRL lights came on
Old Dec 9, 2015
CraigW's Avatar
Re: DRL On
You likely have the separate DRL control box.
Maybe you can touch up some of the solder connections at the relay pins, and the connector pins solder joints as well
Old Jan 21, 2016
mikey1's Avatar
Re: DRL On
this problem has got progressively worse since i started this thread,
its to the point now where my DRL's do not work at all and the DRL is on all the time,
only time the DRL on the dash will disappear is if i put my headlights on manually every time i drive which is a pain the
is there any easy fix for this? if not i guess i will just keep doing what im doing
Old Jan 21, 2016
CraigW's Avatar
Re: DRL On
My 1st thoughts still on this. Get it loose and whack it with a screwdriver handle when drl are inop and watch for changes.
Uan
Aug 23, 2015 03:03 AM
WaryDriver
Aug 16, 2015 11:22 AM
EngiNERD
Aug 9, 2015 08:28 PM
honda.lioness
Aug 6, 2015 11:58 AM
Drix
Aug 5, 2015 12:44 PM
