head gasket, valves replaced...
Old Feb 6, 2013
Orcus332's Avatar
Orcus332 is an unknown quantity at this point
My car is currently in the shop to have the head gasket replaced, timing belt, and water pump done. They sent my head off to the machine shop and just got back to me. Said it needed planed because it was severely warped. Also said some of the exhaust valves were bad and would need replaced too for $300 extra. Any idea if this is something that commonly happens? I know the head can warp, but the valves??? I guess I dont have much of a choice though, so i'm going to have to have it done?
Thanks!
Old Feb 6, 2013
mikey1's Avatar
Re: head gasket, valves replaced...
did the engine overheat at any point in time? that really is the only reason for the head to warp....if it did not, the head should be fine.....
valves do not generally need replacing unless your timing belt snapped and the pistons hit the valves, did this happen?
what was the purpose of all this work? who told you that you needed the work done and why?
Old Feb 6, 2013
Neglected valve adjustment maintenance can lead to burned valves.
"Tight valves burn." They get replaced.
Just sayin....
Old Feb 7, 2013
04 Honda Civic's Avatar
Just sayin....
From what I read and heard..Hondas normally only get adjusted when they get loud?
Were your valves loud?
Old Feb 7, 2013
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
I don't know I adjusted my valves when I replaced my head gasket. The hadn't been touched in ten years and all of them were looser than the maximum spec. I adjust them in the middle of the spec, but later found this interesting read. Honda's Tech Line Summary article ATS050805.
http://www.google.com/url?sa=t&rct=j...42080656,d.cGE
Old Feb 7, 2013
That's what the printed "maintenance guide" suggests for when to adjust them.
Problem is, seems like most of Hondas products tend to TIGHTEN the valves as they age. (Due to stem stretch, "tuliping" and maybe seat recession on some (early CRV for one).
Experience tells this, not the maintenance guides and books.
EDIT: After seeing enough problems caused by valves that tighten up over time, we don't judge by only by listening for noise because that's not the only possible way they can have a problem.
Tight valves don't make noise. Tight valves can cause low manifold vacuum, P0172/rich codes, misfire codes, low compression, and burn.
Loose valves make noise, but don't burn.
HTH
Old Feb 7, 2013
I have always gone for the loose end of the specs on Hondas.
I used to go a wee bit tight on Mazdas with rocker arms, they tended to loosen.
Old water cooled VWs with buckets and shims had a pretty wide range to shoot for, a whole 0.10mm range.
Old air cooled VW engines we set loose so they didn't burn or snap off....
Old Feb 8, 2013
BlueEM2's Avatar
Whachya lookin at?
I haven't done an adjustment in 130k miles. I'm SURE they are out of spec but they aren't loud. I'm not going to do one either lol. Ride it out see what happens
7thgensurvivor
38
Aug 29, 2015 11:50 AM
159
Jul 5, 2015 09:54 PM
jdawgzcivic
Jun 30, 2015 06:35 PM
mrohitredd
May 28, 2015 10:03 AM
HondaHomer
May 14, 2015 12:24 PM
