Check Engine Light on!
Old Mar 7, 2012
  #31
Rahway09's Avatar
Rahway09 is an unknown quantity at this point
Re: Check Engine Light on!
random question where and how much do you guys get your hid replacement bulbs from?
Old Mar 7, 2012
  #32
04 Honda Civic's Avatar
purchased my kit from "theretrofitsource" Buy quality bulbs or they are going to be different colors and continue to burn out.
Old Mar 7, 2012
  #33
Rahway09's Avatar
04 honda civic = i dont have retrofits though! mine are regular
Old Mar 7, 2012
  #34
johndeerebones's Avatar
johndeerebones is a jewel in the roughjohndeerebones is a jewel in the roughjohndeerebones is a jewel in the rough
The tcc solenoid is on the top side of the trans. It is down and a little away from the egr. It is a single solenoid, two wire connector. Held on with 1 6mm bolt(10mm) size wrench needed. I know, had to replace mine. I will take a picture of the old one and the solenoid on the car if you need it. Like said, that is the one code that is circuit related, not mechanical (that code states it). My old one was good, wasn't the problem. I got it offline for 30 or 40 bucks. 200 bucks is obsurd. Don't let anyone tell you aftermarket won't work either. Mine has 20000 miles on it and almost a year, still working. The OEM one is the one laying in my shop. Aftermarket is still on the car.
and you don't "have to" take the airbox off. It does make it easier, but it isn't a have too.... I didn't. I do have long skinny fingers and been a mechanic for a long time, so used to working in weird positions.
Old Mar 7, 2012
  #35
Rahway09's Avatar
Johndeerebones= could you please take a picture please and thanks! it would let me know wat i am looking for! is that the only place u can buy it or can u get it like locally at autozone or etc?
Old Mar 7, 2012
  #36
lol, they have bulbs for regular hid installs. I dont have a retrofit either.
Old Mar 7, 2012
  #37
Rahway09's Avatar
04 honda civic = what kind of bulb does ur car use? mine uses h4 which they dont have
Old Mar 7, 2012
  #38
I believe it looks like this
http://www.transjobber.com/images/80425.jpg
Just did a quick google search.
Old Mar 7, 2012
  #39
Rahway09's Avatar
isnt that the solenoid?
Old Mar 7, 2012
  #40
That's not the TCC solenoid. That is the shift solenoids.
Again...The TCC solenoid is #4 here:
Old Mar 8, 2012
  #41
mac25's Avatar
Dr Krieger of Modification
here yu go bro =D... hope this is it. i took my intake filter off and i have an after market intake. your engine bay will have the stock intake in the way but it's really easy to take off and on. this view is looking from the passanger's side into the engine bay. you can see the fuse box on the left and the batery on the right.
here's how to remove the stock intake. you'll also have to remove a bolt that holds the intake tube on. it's pretty easy to find. after that you can just pull it out of the intake box. then look at the diagram bellow to remove the bolts and ring in order to remove the intake. make sure to unplug the air sensor on the intake before trying to lift the intake box off the throttle body, to avoid damaging it.
Old Mar 8, 2012
  #42
Rahway09's Avatar
Mac 25 = thank you so.much ! Updates coming soon
Old Mar 8, 2012
  #43
Rahway09's Avatar
Hey guys so a couple things did some digging around in my car and found these
But a couple things came up i tried to take off the airbox but couldnt due to the fact that there were two nuts that were in awkward places. also the pcm connectors thats under the steering wheel where the fuses are correct?
Old Mar 12, 2012
  #44
Not it, yes I will get you a pic in a bit...
Old Mar 12, 2012
  #45
Mac25 got it...
Old Mar 12, 2012
  #46
Rahway09's Avatar
i found the piece but idk where the pcm connectors are or how to get to it! also i was not able to remove the airbox because the nuts were stuck on it
Old Mar 13, 2012
  #47
You need long extensions to remove the bolts on the air filter housing.
Old Mar 13, 2012
  #48
Rahway09's Avatar
ok thanks wat about the pcm connectors?
Old Mar 13, 2012
  #49
lazlong's Avatar
You mean the ones that plug into the ECM/PCM ? The ECM/PCM is behind the glovebox. Open the glovebox, pop out the stop on each side and let the door swing all the way down. You should then see the ECM/PCM. The connectors are, in order: A, B, C, etc... from the bottom up.
Old Mar 13, 2012
  #50
Rahway09's Avatar
Thanks so much Lazlong!
Old Apr 6, 2012
  #51
Rahway09's Avatar
Ok so i found the pcm connectors and i tried to do the diy but i think im doing it wrong! I hate being a noob!
Old Apr 6, 2012
  #52
Rahway09's Avatar
Btw i took it to get it fixed and he tried to charge me 65 dollars just to plug it into the computer plus whatever labor and parts it would take to fix it!
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
jetcare101
May 8, 2015 01:33 PM
tylerginevan
Apr 27, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
