manual slipping with a fairly new clutch
Old Oct 11, 2011
pwnsauce's Avatar
pwnsauce is a jewel in the roughpwnsauce is a jewel in the roughpwnsauce is a jewel in the roughpwnsauce is a jewel in the rough
so im at work (delivering pizzas) and i pulled outta the parking lot in first then second then slip into third...like a long slip. i think "okay maybe that was just me" shift to 4th slips again. stop. put it back in 1st, drive, shifts fine, into second slip third slip 4th slip...
but if i shift VERY slowly and carefully it doesnt slip too much just 2nd and a little in 3rd
the clutch has only ~2500 miles on it but the flywheel is still stock i believe.
please tell me i need a new flywheel/clutch and not a new tranny
Old Oct 11, 2011
MindBomber's Avatar
Live for the Twisties
Re: manual slipping with a fairly new clutch
Clutch pedal adjusted properly?
If there's grease/oil on the flywheel surface that will cause major slippage, you're supposed to wipe down the flywheel with brake cleaner before install and be careful to keep it clean.
Old Oct 11, 2011
pwnsauce's Avatar
ahh my next question...how to adjust it?
and hopefully the guy who i bought it from knew that when he replaced it but if he didnt keep it clean i dont see why it would just now 2500 miles later start slipping?
Old Oct 11, 2011
MindBomber's Avatar
There's a few potential causes, none of which should require a new transmission to my knowledge..
Start with the clutch pedal though, it's supposed to be adjusted any time a new clutch is installed.
https://www.civicforums.com/forums/1...djustment.html
Old Oct 11, 2011
pwnsauce's Avatar
and if that doesnt stop it slipping?
Old Oct 12, 2011
MindBomber's Avatar
Slave cylinder in need of replacement.
I think Maxiternity said, he's going to write up a DIY shortly.
Old Oct 12, 2011
pwnsauce's Avatar
nevermind that was it! lol it shifts better than when i first bought it.
thanks mindbomber rep for u
WaryDriver
23
Jul 22, 2015 07:18 PM
159
Jul 5, 2015 09:54 PM
97-DX-Lover
Jun 14, 2015 06:07 PM
begogadashi
Jun 11, 2015 04:04 AM
CiViCPrAnInG2k1
Jan 2, 2002 06:57 AM
