01 Civic LX Loss of power/Rough idle
Old Oct 9, 2011
5g civic's Avatar
5g civic is an unknown quantity at this point
I was driving on the freeway and car startted dropping rpms and dieing and it was hard to start back up and when i pulled over and checked, my radiator had no cap i put a cap on it and the car kept dieing out so i thought my head gasket was blown so i put all new top end gaskets, spark plugs, and adjusted my valves the car is starting fine but when i accelerate the power cts on and off and when i stop after accelratin it idles rough sometimes cutting out I Cant figure it out Please help
Old Oct 10, 2011
MarkoPollo's Avatar
MarkoPollo is an unknown quantity at this point
Re: 01 Civic LX Loss of power/Rough idle
Are you getting funny exhaust?
Old Oct 10, 2011
5g civic's Avatar
The exhaust looks prety normal to me , I do have a crack in my exhaust manifold but I dont thonk that had anything to do with it
Old Oct 10, 2011
ZFreak's Avatar
Honda Crazy
ZFreak is an unknown quantity at this point
Sounds like the timing could be off... i.e. the timing belt could have jumped a tooth. When was the last time the timing belt was changed? May be worth pulling the covers off and making sure everything lines up. If it's off, it will have symptoms you're describing.
Old Oct 12, 2011
5g civic's Avatar
I just set the timing that was my first guess i also compression tested,fuel pressure tested,spark tested, set valve clearance, replaced and gapped spark plugs, tested fuel injectors on my homemade injector tester and measured resistence across them, and it passed every test i have a crack in my exhaust manifold right before my 02 sensor but it ran right before with it cracked is it possible that it got worse a caused misfire
mikemc422
Aug 9, 2018 05:41 PM
beneditti
Jan 15, 2016 12:31 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
vtechcivic
Apr 21, 2015 06:58 PM
streetglower123
Apr 12, 2015 10:56 AM
