Rubbing sound from rear wheels
Old Aug 16, 2011
got2run5's Avatar
got2run5 will become famous soon enoughgot2run5 will become famous soon enough
My car was sitting outside for two weeks while I was out of town. When I got in it and started to go, I heard a sound like something rubbing coming from the back wheel (wheels?) After driving it for two minutes, the sound was gone. Since then, every time I start up the car after having it sit for more than an hour it makes that sound for the first 30 seconds or so of driving although it isn't nearly as bad as when I came back from 2 weeks. I had thought it might be the rear brakes so I didn't put on the parking brake last time I drove it, but this morning it still made the rubbing noise. It sounds like it's coming from the rear passenger wheel, but I guess it could be both. There is also a lot of road noise if that matters... but I thought that was just crappy tires. What do you think this is?
Old Aug 16, 2011
johndeerebones's Avatar
johndeerebones is a jewel in the roughjohndeerebones is a jewel in the roughjohndeerebones is a jewel in the rough
Re: Rubbing sound from rear wheels
Jack it up, spin both and check for looseness. The brakes may have flash rusted while it was parked. My rotors do it every night on the front. Quits after I used the brakes a couple times. If that's all it is no big deal, just annoying. If it was from putting you parking brake on it would be vibrating too.
Old Aug 16, 2011
got2run5's Avatar
It's not only when I brake though. Does it sound like it could be a wheel bearing?
Old Aug 16, 2011
don't know, i did not hear it myself :P
wheel bearing does not rub, FYI.
edspyhill09
Jun 12, 2016 02:45 PM
cmart1209
May 29, 2015 04:52 AM
Pudnite
May 9, 2015 07:51 PM
nontypical
May 4, 2015 04:10 PM
crazydragon
Nov 7, 2001 05:13 PM
