Condensation drip without using AC?
Whachya lookin at?
Hmm... got home from work today,came inside for an hour, went out for a smoke and noticed what seems to be a water drip coming the rear end of the engine, still dripping an hour later. It's dropping right near the catalytic converter. I can't see it from up top but it's very close to the back of the engine. First thing I thought was condensation from the AC system but I haven't used the AC in days... Is it possible to get condensation drip without using the AC system? My coolant level is perfect, and it's definitely not oil. It's water. It hasn't rained here for a few days either. This just kinda caught me off guard. Took my camera to where I couldn't see and I found this, odd... Not sure what it is but it's above the passanger side near the cat:
Important info: I was using defrost It almost seems like a hose that is designed to get rid of condensation... Any info on this would be great I'm intrigued!
I did some more research! Turns out our civics do have a drain hose .. it's part #22 here. I'm assuming that's what's showing in the picture... I guess I answered my own question lol... I should search before posting.. I know. I'm gonna leave this thread undeleted and see if it starts a discussion
http://www.hondapartscheap.com/south...t=0&quantity=0
Re: Condensation drip without using AC?
I have performed the A/C system/compressor release procedure to both my 7th and 8th gens soon after purchase.
I don't want or need the compressor running unless I want it to be.
Do you notice the A/C light coming on when set to defrost?
I think it's smart to blow dry air onto the window to speed up defrosting, no idea why you'd want to disable it.
There is a procedure here to release it. Afterwards, the compressor will still run at floor/def & def, but you can press the A/C button and the compressor and A/C light will go off.
The reason I do not let it run is because after you use it to defrost if you stop using it there is a massive amount of moisture that boils up onto the windshield and is hard to get rid of. I use a bit of heat (when needed) and cracked windows to clear it.
the rear defrost has a "hidden a/c" that comes on even tho the a/c light is off. i have no idea how it works or why, but you can def feel the power loss and even tho its not a full blown a/c run with the fans and all, something is happening behind the scenes.
I think that the power loss associated from the rear defrost being on is due to Alternator load (though I could be wrong, and maybe the previous hypothesis would hold true in that case).
my guess is the compressor turns on but the cooling fans stay off (since cold air is not needed, just dry air). the rear defrost coil does take up quite a few amps, but not enough to notice from driving. the radiator fan uses more amps and that does cause a noticable power loss. these darn civics and their weak alternators lol.
on a side note, new cars are starting to come with adaptive air conditioning that controls how humid or dry the air is.
Scout1
Oct 5, 2015 01:33 PM
SolidHollow
15
Sep 13, 2015 11:18 AM
Greenmonster
Aug 21, 2015 07:40 PM
