Weird noise at start up and turn? Power Steering?
Old Apr 9, 2011
DH757's Avatar
DH757 is an unknown quantity at this point
Hey guys,
I've found that when I start my car and I turn the steering wheel, I hear a sort of noise. It sounds like "gas" going through a pipe, don't think it could be the struts.
After that, driving is normal as usual. It doesn't make the noise anymore until next start up. I checked the Power Steering fluid and it's over the Upper Level line, is that bad?
Anyone else know what could cause the noise? Or is it normal for a Civic to do this?
Thanks
Old Aug 20, 2017
pdfor's Avatar
pdfor is an unknown quantity at this point
Re: Weird noise at start up and turn? Power Steering?
DH757,
I experience a sound identical to the one you describe on my 03 Civic EX. It is just at cold startup and seems to be connected to the steering system.
We have an 05 Odyssey which has a very similar sound that occurs exactly the same way - cold start turning the steering wheel.
Have you diagnosed this issue on your civic?
I frequently check all fluids and the PS fluid on both vehicles is fine.
Thanks
Old Aug 20, 2017
RustyShackle's Avatar
RustyShackle will become famous soon enough
I notice the exact same thing as I turn to head down the driveway after starting cold.
Sounds like a short psshh.
Old Aug 21, 2017
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Check the o-ring for leaking in the inlet to the PS reservoir. Common issue. Same deal for the Odysseys.
bravo79
Suspension
18
Feb 10, 2022 09:52 PM
moorebl
Aug 29, 2015 08:39 PM
edgenet
May 2, 2015 08:00 PM
bsmiley
Apr 27, 2015 01:27 PM
SSMatey
Apr 13, 2015 06:09 PM
