Bizarre SRS light issue
Old Apr 16, 2009
Monochromatico's Avatar
Monochromatico is an unknown quantity at this point
Hey guys, quick question. I was detailing my car yesterday as per the norm (2001 Civic LX 5spd), shampooed the carpets, the full shabang. Anyways, everything was working perfect up until this point. Now, here's the issue. I go out to drive my car this morning and it starts up fine. Here's where it gets weird. My stereo loses power, I look on the dash and my SRS light is on, solid. This wasn't on before. Car doesn't drive any differently, it's just the light on with no power to my stereo.
Any ideas..?
Old Apr 16, 2009
wallydude03's Avatar
wallydude03 will become famous soon enough
Re: Bizarre SRS light issue
did you check the fuses? a stereo just doesnt quit one day, a fuse probably went.
Old Apr 16, 2009
I don't think it's the fuse, because the stereo will start up with the car every time. Just give it ten seconds or so and the exact same time the SRS light flicks on, the stereo loses power. If I turn off the engine and just let it sit in key position 2 (battery on), the stereo works fine. It's only when I start the engine and the car goes through it's checks that the stereo turns off.
As I said. It's bizarre.
Old Apr 17, 2009
is the stereo aftermarket? could be a wiring problem with the ignition.
Old Apr 17, 2009
It is, yeah. But I've had it in there for months, and could the ignition link to the SRS?
Old Apr 17, 2009
its possible, but usually the srs light gets triggered by low battery voltage. maybe check the charging system (alternator) and battery.
Old Apr 17, 2009
Perhaps.. A headlight also burned out today, and it seemed like my daytime running lights were flickering.
Maybe the alternator is to blame? Maybe I got some water on it.. ****.
Old Apr 17, 2009
TRIZ's Avatar
Did you remove the seats at all... or disconnect the connectors underneath them -possibly on accident? That would explain the SRS light. As for the radio... I have no idea.
Old Apr 17, 2009
I didn't remove the seats, but they did get moved back and forth. I'll make sure I check the connectors. The SRS has to be linked to the radio going off, maybe the radio is piggybacking on the mostly-unused SRS detection. Ugh, I don't know.
Old Apr 17, 2009
TRIZ's Avatar
If the seat connectors were the problem, simply reconnecting the connectors wont disable the SRS light, you'll have to do the SRS reset light trick with the paperclip.
Old Apr 17, 2009
Seat connectors weren't the problem, starting to think it's something more substansial. Both of my new headlight bulbs burned out today. Ugh, this is a pain in the ***.
Old Apr 17, 2009
TRIZ's Avatar
Sounds like a ground issue.. OR... ARE YOU SURE that your dont have a VW??
Old Apr 17, 2009
Hahah, pretty sure, though the other car in the family is a 2003 Jetta. I hope it hasn't rubbed off on my car!
Though the Jetta has had a problem free life. Unlike my car. :|
Old Apr 17, 2009
TRIZ's Avatar
Damn... how exactly did you go about cleaning the carpets and detailing the car... did you do anything in the engine bay such as hose it off or apply in products in there?
Old Apr 17, 2009
I used some degreaser in the engine bay, but put plastic bags over my air intake, battery, and tried to get one over the alternator. It might have been a bit exposed, but I avoided that area anyways, I let it sit for a while and then hosed it off. Otherwise I just used some armorall oxiclean and vacuumed it out of the carpets.
I've done the same thing to my engine before, though. that's what's getting me.
**** I did it the first time without bags no less.
Old Apr 17, 2009
TRIZ's Avatar
Sounds like you didnt start your engine up right away after your hosed it off?
Old Apr 18, 2009
That would be accurate.
.. is that bad?
jimmyfloyd
May 20, 2015 07:06 PM
Ma213802
May 18, 2015 07:01 AM
cukaracha
May 16, 2015 02:11 PM
bo_red
Transmission
May 3, 2015 09:14 PM
SimDogg
Nov 27, 2001 04:20 PM
