Squeak Noise When turning
Hi,
Whenever I do a quick/sharp turn a squeaky noise appears....it sounds like it is coming from the seat...so with the car parked I placed my foot on the foot rest and pushed my self against the seat really hard and I can hear the noise...is something loose under the seat or something? Anyone have the same problem?
Re: Squeak Noise When turning
check the plastic covering the seat bolts or check under the seat for anything rubbing/pressing on something. Could it be your power steering pump?
mine did it when I had my esII sedan, and i also had the rocking problem which was covered in a technical service bulletin I believe. if it's something that'll really bug you, take your seat out and lube up any metal on metal.
civicns
May 8, 2015 09:49 PM
edgenet
May 2, 2015 08:00 PM
SSMatey
Apr 13, 2015 06:09 PM
