oil in intake
Old Apr 11, 2007
02civic21's Avatar
Ricky Bobby style, IWGF
02civic21 is a jewel in the rough02civic21 is a jewel in the rough02civic21 is a jewel in the rough
oil in intake
ive got oil in the throttle body and in the intake manifold i took off the valve cover and checked seals but dont see anything wrong anywhere. the car wont run just turns. but i think it might be the pcv valve i could be wrong i dont want to take off the head i just dont have the time right now with work/school but i guess ill have to make time if i have to
any thoughts????
Old Apr 11, 2007
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
Re: oil in intake
I curious as well...
I would think it’s a gasket but I don’t know.
Bump for an answer
Old Apr 11, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
Re: oil in intake
Completely normal. Its the crank case breather blowing vapor back in.
You can thank the EPA
Old Apr 11, 2007
Alpha 5's Avatar
Re: oil in intake
That is why I put a bolt in my intake. I also put a little filter on the valve cover. Here is a pic.
Old Apr 11, 2007
02civic21's Avatar
Re: oil in intake
ok the car wont run i dont think its normal vapor u cant see normal vapor because its recirculated this is a visible amount of oil in the intake like prolly a quarter cup
Old Apr 11, 2007
Jap-Euro Fusion
Re: oil in intake
Vapor is visible, a quarter cup is A LOT. I'm thinkin fried valve seals, or if the PCV valve is stuck shut then everything is venting through the valve cover and its blowing out a lot more than normal.
Old Apr 11, 2007
02BLKCIVIC's Avatar
Re: oil in intake
hmmmmmm
Old Apr 12, 2007
02civic21's Avatar
Re: oil in intake
ok well the pcv valve is fine checkd it last night so im gonna change the oil and clean the spark plugs and see what that does
reason for the step down is that i think i put synthetic in it change before last so the conventional might not be able to stand up to the heat
Old Apr 12, 2007
02civic21's Avatar
Re: oil in intake
yea so what kind of bolt did u put in there and why did you do it did you have the same or similar problem
Old Apr 12, 2007
02civic21's Avatar
Re: oil in intake
yea so why did you put a bolt in there and is it a specific kind of bolt or just any ol bolt
Old Apr 16, 2007
DsevenEm2's Avatar
This is Myspace
Re: oil in intake
why would u do that in the first place....the original oem airbox has a tube going from the filter box to the valve cover anyway...when u get an aftermarket intake u still connect a tube from the intake to the valve cover...is that bad???? i have it connectd too and dont see why i wouldnt.. n i dont have oil in my intake.
Old May 11, 2007
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
Re: oil in intake
you could make an oil catch can that'll keep oil out of there.
Dani1993
Jul 24, 2015 09:02 AM
hoofboy
Jul 17, 2015 04:27 PM
LorenzoC0395
Jul 14, 2015 08:46 PM
NoobyKid
Jul 13, 2015 07:53 AM
7thgensurvivor
Jul 5, 2015 12:17 PM
