SRS light stay on
Old Apr 12, 2007
Dark2k1's Avatar
French ass K20a2 powered
Dark2k1 is an unknown quantity at this point
SRS light stay on
I remove i sterring wheel this winter and I try to erase the SRS light with this procedure...
It is a yellow connector with two wires in it that is plugged into the fuse box, unplug it and pull it down. Once you have done that you can begin the process of erasing the memory. NOTE: This will only reset your SRS System if what caused it to trigger has been fixed, Ex: turning the ignition on with any SRS Plugs disconnected, such as pulling your seat out.
1st step in erasing the memory is to turn the ignition off and connect the SCS Service connector to the MES Plug,
2nd Turn Ignition on. SRS indicator light will come on for about 6 seconds then go off.
3rd Disconnect SCS service connector for MES connector within 4 seconds after SRS indicator light goes off. SRS indicator light will come on again.
4th Reconnect SCS service connector the MES connector within 4 seconds after SRS light comes on. SRS indicator light will go off.
5th Disconnect SCS service connector from MES connector within 4 seconds. SRS indicator light will indicate that memory is erased by blinking 2 times.
6th Turn ignition off, and wait 10 seconds. Start vehicle like normal and light should come on and go out like normal. You have reset your SRS light, congrats.
If it does not work the first time try it again, the timing has to be perfect. My first time it took me 3 attempts before it worked, but it did work.
I found it in the DIY section of this forum...
but in my case... the light blink 3 times... and this one stay on ??
Someone can help me ??
Old Apr 18, 2007
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
Re: SRS light stay on
I don't understand when you're supposed to reconnect the plug.
edit: i'm an idiot. it's a dummy spot in the harness.
Burnout
Jul 15, 2022 10:24 PM
Blazz
May 25, 2015 10:56 PM
Ma213802
May 18, 2015 07:01 AM
cukaracha
May 16, 2015 02:11 PM
SimDogg
Nov 27, 2001 04:20 PM
