New Cruise Control Issue???
Old Sep 10, 2006
BigRedEXcoupe's Avatar
BigRedEXcoupe is an unknown quantity at this point
While on my way home from the store tonight, I set my cruise control. Approximately a second later there was a click from under the hood and it kicked in. That worried me, so I turned it off, only for it to make the same sound when I turned it off. The sound is not coming from the buttons on the wheel, but sound like they are coming from the cowl section of the car.
If I recall, the cruise lever mechanism is directly next to the throttle, like in front of it. There is a gap between the two, about a 1/4 inch. I notice that when I have someone rev the motor, the throttle moves before hitting the cruise lever. Isn't there not supposed to be a gap between the two??? and if so, is there a way to tighten it to eliminate the gap???
Like so: (Sorry for poor diagram, but can't post pics yet.
I M__________I !
n a__________I !
t n__________I !
a i______CC --I !
k____(1/4" gap) !
e_________TH --!
Thanks for all the help that anyone can provide this newb
Old Sep 11, 2006
nj_represent's Avatar
nj_represent is an unknown quantity at this point
you could try the adjusting nut on the throttle body. Take off the airbox from the throttle body and you should see a nut and you loosen the nut and the threaded rod. Its kinda hard to explain, I think there is a DIY around here. That click may be a relay, I have the wiring diagram but I just woke up. And that 1/4" might be ok because if I remember correctly on the double pull part on the throttle body there is a little bit of play.
Old Feb 13, 2015
methmal132's Avatar
methmal132 is an unknown quantity at this point
Re: New Cruise Control Issue???
Hello Friends,
I need to find the FD3 OR FD1 HONDA CIVIC Cruise controller wiring diagram? Is there a way to get it.
Thanks
Hasitha
KronikScott
Jun 9, 2015 08:00 PM
MamaBear2015
May 27, 2015 12:04 PM
cukaracha
May 16, 2015 02:11 PM
o0aznbboy0o
Feb 6, 2002 06:14 AM
Civic316
Electronics
Dec 10, 2001 12:03 PM
