P0113 ??'s
Old Aug 29, 2005
cg95660's Avatar
Wanna see a donkey show?
cg95660 is an unknown quantity at this point
P0113 ??'s
I got a p0113 code about a month ago. It cleared on its own. But it came back. So decided that it must be a bad IAT and bought a new one. I put it on and clear the ecu. After driving up the street the cel came back on for the same ****. P0113 with a brand IAT. So I clear the ecu again but have not had time to drive it around. Has any body had any trouble like this?? I have a v2 cold air, dc header, cat back. Any thing would help. Cuase the next step is to go back to stock intake box!
Old Aug 29, 2005
streetglower's Avatar
well if you put in a new sensor and the check engine light came right back on, then the sensor isnt the problem. you could have a bad connection between the sensor and connecter, an wiring issue between the IAT sensor and the ECM, or a problem with the ECM. With this code, unless you have a scan tool, better take it to a dealer or shop to check out.
Old Aug 29, 2005
cg95660's Avatar
I do have a obd2 scanner. Its the only code and all other systems are fine. I will drive her to work tonight and ill see if it does it again. Maybe i did not reset the ecu long enough!
Old Aug 29, 2005
remove the #6 fuse for 10 seconds, then put back in. then go drive around,if it comes back on, then you have another problem.
With any check engine light, there are several possibilities on what the problem could be. Even if everything else is working, and the sensor itself is fine, you could have a problem in the ECU with that circuit. Or a problem in the wiring to the IAT sensor. You have to follow the specific procedures in the service manaul to diagnose that code.
And you need a scanner that will give you sensor values for several of the under hood sensors.
Old Aug 30, 2005
cg95660's Avatar
Thanks for the replies. I reset the ecu for longer and made sure the connector was plugged tight. I do think the plug is causing the probs. Any way I drove it around all day today and it good to go.
Old Nov 12, 2017
SSG03's Avatar
SSG03 is an unknown quantity at this point
Re: P0113 ??'s
Can anybody help me I have a cold air intake. I have a code p0113. I can not find the sensor.
Old Nov 12, 2017
Wankenstein's Avatar
Re: P0113 ??'s
It's usually located on the cold air intake bend near the throttle body. Also, it may be located on the intake manifold itself if you have an LS intake. Post pics of the CAI and intake manifold.
Old Nov 12, 2017
SSG03's Avatar
Re: P0113 ??'s
michael0219
Sep 1, 2015 10:25 PM
USCGBM
Nov 18, 2014 10:38 AM
bimmuvfab
19
May 6, 2014 10:06 PM
CivicBoi1998
Mar 5, 2014 08:10 PM
tommyhoang_ta
17
Feb 7, 2005 04:03 AM
