Brake Light on
Old May 26, 2005
SevenCyrus's Avatar
Se7enCyrus Racing/Motorsports
SevenCyrus will become famous soon enoughSevenCyrus will become famous soon enough
Brake Light on
The brake light turns on even when i put downt he E-brake, anyone know whats the deal?
Old May 26, 2005
CraigW's Avatar
Have you checked the brake fluid ???
Does the light flicker any if you work the parking brake up and down ?
Old May 26, 2005
tacheon's Avatar
tacheon is on a distinguished road
The brake warning light does much more than tell you if your parking brake is up. It tells you when there is a fault in your brake system (caused by a number of situations). It can be caused by a failed master cylinder, leaking brake system, faulty sender at the master cylinder, faulty parking brake switch.
Old May 26, 2005
SevenCyrus's Avatar
shiiiit, i did not no this. Alright, so what should i do? Take to Honda? Thanks guys
Old May 26, 2005
CraigW's Avatar
If it is low don't add fluid. If the mileage is 40-60 k miles you may need new pads. When the pads are replaced the fluid level will return to near normal, If you add fluid it will need to have some removed before the new pads are installed. If the pads are o.k. and the fluid is low, you may have a leak.
All easy stuff to check.
Old May 26, 2005
SevenCyrus's Avatar
its got only 9K miles How i check for leak?
Old May 27, 2005
CraigW's Avatar
Is the fluid low ??
At 9k for it to be low enough for the light to come on you would have to have a leak.
You should let Honda fix it.
Poopies
Apr 20, 2017 11:36 PM
MamaBear2015
May 27, 2015 12:04 PM
trellex
May 24, 2015 04:39 PM
Ma213802
May 18, 2015 07:01 AM
McD
Apr 29, 2015 03:50 PM
