Electrical Post information/questions/Issues about Electric parts here.
Vsa power steering light code p2101
Old Mar 29, 2023
kountry10's Avatar
kountry10 is an unknown quantity at this point
The other day drove my car home fine shut it off and went to step out again when i started my car it stalled right away i tried starting it again while goving gas and had no gas pedal response car stalled again .. waited 5 mins the car then started but vsa and power steering light started flashing. When i scanned the car i got a p2101 code for throttle body actuator. I disconnected the battery for 15+ mins cleaned the throttle body and mass airflow sensor. When i started the car it was idleing at 3000rpm then rose to 4,000 rpms then dropped back to 3000rpms and continued to repeat that sequence i disconnected my mass airflow sensor while care was running and it didnt make a difference car even started with it unplugged but ran poorly then had that idle issue again. I changed spark plugs 2 weeks ago and cleaned my maf with brake cleaner which i read ruins the sensor after doing it but can the issue start 2 weeks after spraying it down. Before i changed the spark plugs the car would bog under heavy load and lose power for a split second then begin with full power in every gear. Not sure where else to check 02 sensor also destroyed and not working 100%
Old Mar 29, 2023
Re: Vsa power steering light code p2101
first fully charge battery, when dashboard lits up like a christmas tree in these cars, there is not enough electrical power and electronics go crazy. If that works, either battery or charging system is not good - 1st thing to check
Old Mar 29, 2023
Colin42's Avatar
Check battery connections
redrocket87
Feb 15, 2021 01:12 PM
razordx
Feb 2, 2019 01:28 AM
zxzkilme2
26
Jun 15, 2016 11:23 PM
jponto07
Oct 26, 2010 04:48 PM
IRPancake
Oct 8, 2009 12:21 PM
