Throttle cuts out, no CEL light
Old Jan 31, 2019
razordx's Avatar
razordx is an unknown quantity at this point
Hey guys.
I have 96 Civic DX Hatch that has been great to me... up until now.
I'm having an issue where the engine will cut out once it goes beyond 2000RPM. Idle and up to 2000rpms everything is normal, but beyond that (with the throttle held steady) the rpms will drop to 1000, go back to wherever the throttle is, drop to 1000rpm, and on and on.
There is no CEL light on now, however there was a code for oxygen sensor (replaced, code gone) and a code for throttle position sensor being below/above the min/max values (replaced, calibrated properly, code gone).
I thought I had finally fixed it with the O2 sensor replacement, but once the engine warmed up the problem re-emerged. Disconnected the battery for 10 minutes, let car idle for 10 minutes, still have the same issue.
Does anyone know what may be causing this?
Old Feb 1, 2019
mac25's Avatar
Dr Krieger of Modification
Re: Throttle cuts out, no CEL light
Was the TPS OEM or aftermarket?
Old Feb 1, 2019
Jp7's Avatar
Jp7
Jp7 is an unknown quantity at this point
I had a higher RPM intermittent miss that was caused by oil that leaked its way pass the donut seals where the spark plugs go. Mine was 3000+ but as your RPM increases it raises cylinder pressure making it harder for the spark to jump the gap. If you have anything that is a "way out" for the spark to escape the plug wires (or anywhere on the secondary side) it will take that path rather than through the spark plug gap.
Old Feb 1, 2019
razordx's Avatar
Aftermarket, it was the only one the local Advance Auto had in stock. After installation everything read as it should with a voltmeter.
I haven't pulled the plugs yet to check, will do that in the morning and report what I find. Thanks!
Old Feb 1, 2019
Colin42's Avatar
A junkyard OEM one is probably better than an aftermarket one fyi
Old Feb 2, 2019
What value or spec did you set it to?
I would adjust the TPS so its voltage output is exactly 0.49 Volts @ closed throttle
SpeedReeeser516
May 22, 2018 07:08 PM
Joenawrockis
May 21, 2018 08:24 AM
Klaula86
Oct 24, 2017 07:02 AM
td1238
Feb 4, 2012 12:04 AM
td1238
Jan 31, 2012 11:50 PM
