Electrical Post information/questions/Issues about Electric parts here.
07 1.8L TDC Sensor (Cam Position Sensor)
Old Aug 10, 2021
GerryR's Avatar
GerryR is an unknown quantity at this point
I was hoping someone can help me as Honda can not seem to find the right (TDC) cam position sensor for my 07 Civic (bought it at an auction). I have been to the junkyard to look at heads from the same year and same motor but the sensor itself in that motor looks the same, same 3 pins but the configuration of the slots on the sides are in different spots and the clip part that secures it to the harness is skinnier than the one Honda is ordering. When I checked the listings on Rockauto the picture and part # are the same as the one from Honda. Could this be a crate motor from Japan with a different style wiring harness and sensor? Someone mentioned that to me.
Old Aug 10, 2021
Re: 07 1.8L TDC Sensor (Cam Position Sensor)
check your engine code.
it's stamped in a square in the bottom where the engine mates tot he trans.
previous owner could have dropped different engine there
https://www.civicforums.com/forums/1...ation-d17.html
Old Aug 10, 2021
BrotatoChip's Avatar
Super Moderator
Did you remove the sensor yourself? That looks like the crankshaft position sensor.
ron36535
Nov 9, 2018 07:39 AM
mikey1
Jul 22, 2018 01:10 PM
honda.lioness
Sep 17, 2017 04:19 PM
contevo
May 8, 2015 03:49 PM
floyd107
Feb 6, 2011 03:29 PM
