P0340 Help ?
Old Jul 20, 2018
mikey1's Avatar
P0340 Help ?
long story short,
got slight hesitating during accelleration a few days ago around 3,000RPM
only happen once about ever 5-6 times i accellerated from stop
today the car died completely while driving, it will start up sometimes for a few mins, other times not start, completely random,
only showing one code P0340
is it most likely to be the cam sensor itself?
is there a way i can test voltages at the cam sensor plug to verify that it is the sensor??
can this be the crank sensor, or a problem with the crank sensor wiring? or is that a seperate/different code?
Old Jul 20, 2018
Re: P0340 Help ?
Intermittent.....Probably temperature related?
I'd probably make sure the harness connector terminals have good tension then toss a (honda) cam sensor at it
Old Jul 20, 2018
mikey1's Avatar
Re: P0340 Help ?
it was very intermittent for a few days,
first it was only happening every 5 -10 mins of driving,
now its happening every 30 seconds or sooner, but sometimes it can idle for 5-10 mins without any issue at all,
it happens more while actually driving/accellerating.....not much at idle, if at all
Old Jul 20, 2018
mikey1's Avatar
Re: P0340 Help ?
i just used the instruction in post #2 here......
https://honda-tech.com/forums/honda-...0-rpm-3081569/
and going by the results from that it is apparently a faulty sensor, i guess i will throw a new one in
Old Jul 22, 2018
mikey1's Avatar
Re: P0340 Help ?
new cam sensor fixed it
a few hours work, and a bit of
Old Jul 22, 2018
Re: P0340 Help ?
Right on!
My thinking: The fact it's an intermittent issue tells me voltages you would measure have to be correct at least while it is working, therefore the likely causes would be a failing sensor, or possibly poor contact of wiring terminals in any part of the circuits involved.
chrisdao1
Aug 17, 2021 09:49 AM
contevo
May 8, 2015 03:49 PM
1.6el
Oct 2, 2012 02:36 PM
soundquest
Jun 21, 2012 04:18 PM
sleepy-racer
Buy, Sell, & Trade - Archive
Mar 1, 2007 08:47 AM
