When i shift to gear 4 and 5 my lever pulls out back to nuetral
Old Jan 19, 2023
wonaghise's Avatar
wonaghise is an unknown quantity at this point
Hello please i have a challenge with my 08 civic, when i shift from gear 1 - 3, my gear shifter stays in place but once i shift to 4 its pulls right out immediately. What can i do to fix this problem?
Old Jan 19, 2023
Re: When i shift to gear 4 and 5 my lever pulls out back to nuetral
So.. there are a few things that can contribute to this.
1) Gear synchros. Worn synchros can cause gear popping out issues. Hardest and most expensive fix because it requires a teardown of the transmission.
2) Worn motor mounts could possibly attribute to this. The common motor mount that goes out is the passenger side on the 8thgens, but that's opposite side of the engine bay as the trans. Mid-cost since motor mounts can be like $150+ for one of quality and/or OEM. I guess it could be cheap if you got some poly motor mount inserts, but that could possibly introduce a level of NVH (noise/vibration/harshness) that you may not want to deal with.
3) Doing a manual trans fluid change can be a band-aid fix, and sometimes last a while. I had 2nd gear popping out issues on my 2002 civic, and a trans fluid change fixed it for at least a solid 100k. I also fixed my worn out trans-side motor mount at the same time, so it was a 2 birds, one stone sorta deal. I really didn't feel like tearing down a transmission. Possibly cheapest fix, and if the trans fluid has never been changed, likely long overdue anyways.
Faisal_blooshi
Transmission
Dec 19, 2017 08:29 AM
n32
Jan 1, 2016 02:17 AM
taehoshi
Apr 20, 2006 08:46 PM
Silver_Si
Apr 22, 2005 08:46 PM
ptechricer
Aug 24, 2003 12:45 PM
