2nd gear
Old Aug 10, 2003
ptechricer's Avatar
ptechricer is an unknown quantity at this point
Unhappy 2nd gear
Latley I have been driving down the road, and when I shift into second gear, the shifter pops out of gear. And will not go back into gear untill I shift in another gear. Please help.
Old Aug 10, 2003
ptechricer's Avatar
I already 37,000 miles on it, and I have a DC sport short shifter.
Old Aug 11, 2003
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Try first lubricating the cables at the transmission. Maybe you'll get lucky and the shift cable is just binding a little. If that's not it, then it's the tranny per hoda's TSB.
Old Aug 15, 2003
RedRider's Avatar
RedRider is an unknown quantity at this point
Had the same problem with mine. Mine happened more often when it was over 90 degrees out. Kept getting worse and eventually started popping out of 5th too. Took it to a Honda dealer and after 2 months of waiting for parts they replaced the cables and bushings. Parts were on back order because it is a common problem. Car has only 20K so it was covered under warranty.
Old Aug 18, 2003
thirdhonda's Avatar
thirdhonda is an unknown quantity at this point
RedRider:
Is your car an 01 or 02?
Old Aug 18, 2003
Green Civic's Avatar
I have 35k. I can still go to honda and get them to fix it? Right? My 2nd pops out ever now and then. Its more when I get ready to shift out of the gear that it pops out.
Old Aug 18, 2003
Ronin's Avatar
Ronin is an unknown quantity at this point
There's a TSB for 2nd gear problems (check the Stickies at the top of this forum) ... make a copy and be sure to show that to your dealer .
Old Aug 21, 2003
thiscrackerntam's Avatar
thiscrackerntam will become famous soon enoughthiscrackerntam will become famous soon enough
Man I have a 01 EX with 32k miles, I hope I dont start running into this problem. I've never encountered it before.
Old Aug 24, 2003
RedRider's Avatar
Standard Warranty is 3 yrs/36k miles unless you've purchased additional warranty. Get it in soon and report it before 36k limit.
Old Aug 24, 2003
RedRider's Avatar
Yeah I did take in the TSB and show it to them. THe work they did though was not related to the TSB. Now the shifts fell much firmer and tighter than before.
Tyler93
Mar 20, 2016 09:03 PM
Whitexj
Sep 30, 2015 02:04 AM
meicalnissyen
Sep 22, 2015 06:20 PM
BBrosario
Sep 17, 2015 07:51 PM
rayaan_wasty
Sep 14, 2015 02:00 PM
