8th gen trans
Old Jul 6, 2021
BigpapaBoi24's Avatar
BigpapaBoi24 is an unknown quantity at this point
8th gen trans
Ok I replaced the clutch in my 09 civic si and when we got it done got in it and started it and wont go into gear I blead the slave cylinder and still nothing and I know I didn't get anything backwards just need some suggestions I need my car back
Old Jul 6, 2021
FRSam's Avatar
Click Here
Re: 8th gen trans
Will it go into gear but the clutch won’t engage? Or does it physically refuse to shift out of the neutral position?
Old Jul 6, 2021
BrotatoChip's Avatar
Super Moderator
Re: 8th gen trans
Along with that, will it go in gear while the engine is off but not when the engine is on?
Old Jul 6, 2021
Re: 8th gen trans
While it is running it will not come out of neutral and it does go into gear when the engine is off
Old Jul 6, 2021
Re: 8th gen trans
clutch is not completely releasing.
Old Jul 6, 2021
Re: 8th gen trans
I know that I'm trying to figure out why
Old Jul 6, 2021
Colin42's Avatar
Re: 8th gen trans
These cars are a pain to bleed. Get a helper or a power bleeder/fluid extractor
Old Jul 6, 2021
Re: 8th gen trans
could also be failing slave. or the MC
Old Jul 6, 2021
Re: 8th gen trans
Wouldn't the pedal be soft it still needed to be blead
Old Jul 6, 2021
Colin42's Avatar
Re: 8th gen trans
Not necessarily, get someone to watch the clutch fork while you press the pedal. You probably won't see it move the full amount of travel
Old Jul 7, 2021
Super Moderator
Re: 8th gen trans
I believe the clutch pedal is adjustable on the 8th gen. Since you replaced the clutch you may have to adjust the pedal.
Old Jul 7, 2021
Re: 8th gen trans
Does anyone know how much the clutch fork is supposed to move because I put a stage 2 in my car and the old clutch wasn't bad when I took it out but the clutch was slipping so I'm thinking my cmc is going bad and maybe just not allowing the slave to fully disengage my clutch the car has 290k miles and I'm pretty sure the cmc has never been replaced but when we bleed it the pedal is stiff but the fluid is black
Old Jul 8, 2021
Re: 8th gen trans
?!? You would need some biiig modifications to need a stage 2 clutch?!?
s2kdemon
Apr 26, 2018 02:42 PM
ScottMorrison
Mar 13, 2014 10:51 PM
jess21
Oct 1, 2013 06:43 PM
98civichatch
Jun 23, 2013 09:22 PM
huebenthal
Jan 21, 2012 08:05 PM
