manual trans pops out of 5th
ok, so my trans on my 03 ex coupe was popping out of 5th while driving. it got so bad, it wouldnt stay in 5th at all. i could feel the gears engage, i was able get forward motion, but as soon as i took my hand off the shifter, it would pop out of gear, with a visceral buck. i replaced the trans with a rebuilt one, and it worked fine for a month, and on my way home from work today, the new trans started doing it too. now, admittedly, i havent had the chance to check to fluid, but i just filled it with OEM fluid a month ago, and ive only driven about 1000 miles on it. i just dont understand, and its quite frustrating.
please help.
please help.
Re: manual trans pops out of 5th
Sounds like one of your shifter cables got a bind in it or when your reinstalled them maybe they weren’t aligned correctly, maybe cable got routed wrongly around the rear mount, maybe shifter ball is split
If the cable almost puts the transmission all the way into 5th, but just doesn’t push it far enough for the indent ball to lock it you could expect it to pop out.
ok, so today im off work and am going to go ahead and check and change the fluid. i still dont understand how that could be it, since i filled it less than a month/1000 miles ago.
yea my first step would be to remove the resonator, engine off, have someone put it into 5th and then yank on the linkage and see if I could move it further at the transmission.
ok, so i got a chance to check the fluid level today. it was full, fluid was the right color (i mean its less than 1000 miles old, so im not surprised), and no leaks on the tranny. any help would be appreciated. im thinking im gonna have to go ahead and find the money to take it somewhere to get looked at, because im stumped.
Inspect cables and linkages as mentioned above
Shift lever....in 5th gear is the lever travel (or throw distance) the same as 1st and 3rd? If obstruction were blocking the lever from reaching full travel you'd surely feel something unusual in the movement
its only in 5th though, how strange.
it seems to be in the right place when shifting into 5th. ill walk outside and look at the cables and shifter, gimme a minute.
ok, ran through the gears while on jack stands, shifts smoothly. positive lock into 5th, as well as the other gears, including reverse. i regreased all the moving parts. didnt see any binding in the cables.
Maybe new-to-you used trans came with its own set of problems?
Still got your original to rebuild?
colbyem2
Nov 20, 2012 12:57 PM
SurrealCivic
Feb 16, 2005 10:18 AM
BasicEssentials2k1
Feb 17, 2004 01:37 PM
scarpones
16
May 31, 2003 06:20 PM
armageddon
18
May 14, 2002 11:31 AM
