Rattling noise on cold start up
Old Apr 5, 2022
dha12oks's Avatar
dha12oks is an unknown quantity at this point
Hi,
Just wondering if someone can help, I have a Civic Type-R 07 reg and I've noticed recently that there's a rattling sound coming from the engine on a cold start up but goes away on 2nd or more start up if not left for a while.
I thought maybe it was the oil, so I topped that up as it was a bit low, but after leaving it for maybe 7 hours and starting it again it still is rattling, it idles perfectly idling at 2000 and dies down eventually to around 1000 (as expected).
What else would it be, worse case scenario a piston ring? Any feedback is appreciated, thanks.
Old Apr 5, 2022
Re: Rattling noise on cold start up
open the hood, start inspecting.
screw driver can pinpoint where the rattle is coming from
you have not given any reason you suspect it is internal to engine, so suppose it could be something else.
Old Apr 5, 2022
dha12oks's Avatar
Hi mate,
Forgot to mention that we've done this, myself and my brother was checking it out and it does indeed sound like its coming from the engine block.
That said I've not done the screw driver trick yet (totally forgot tbh but I do watch a lot of Scotty's vids on YT xD), I'll have to do that when I got another person with as yeah I cannot do this by myself, only issue is we'd have to wait a while for the engine to settle, I'm guessing it's the piston rings though to be honest, as it starts up fine after the 2nd start, guessing they're lubricated more on a 2nd start up.
Old Apr 5, 2022
BrotatoChip's Avatar
Super Moderator
Piston rings will never rattle.
Maybe it needs a valve adjustment.
Old Apr 5, 2022
dha12oks's Avatar
Ah okay that's good to know, would that explain the cold start rattle and then okay on the 2nd+ starts?
Old Apr 5, 2022
Super Moderator
Possibly. When the engine sits for a while oil will drain from the head back into the oil pan. On the first start the cams/rollers/valves are "dry" and make a little noise. They quickly get oil from the pump once running so if restarted soon after won't make any noise.
Old Apr 5, 2022
dha12oks's Avatar
Okay thanks mate I'll either get that looked into or with a help from my brothers dad who was a mechanic, take off the head cover/block and inspect.
Cheers again.
Old Apr 5, 2022
Colin42's Avatar
Heat shield?
Old Apr 5, 2022
dha12oks's Avatar
Originally Posted by Colin42
Heat shield?
If I understand you correctly, are you talking about the cover that is covering the exhaust manifold?
If so that's secure.
Old Apr 5, 2022
Colin42's Avatar
There's a few different ones on the manifold and exhaust. Try tapping on the manifold and exhaust with a rubber mallet when it's cold to see if you can hear a rattle
Old Apr 5, 2022
dha12oks's Avatar
Okay cheers mate, I'll check it in an hour or so as I've just driven it.
earthboy
Aug 15, 2021 07:47 PM
growapair2
Jul 19, 2014 12:56 PM
amuthini
Dec 13, 2005 07:10 AM
malice29r
Jan 2, 2003 02:54 AM
01SOHCcivic
33
Mar 16, 2002 12:39 AM
