2014 Civic LX intermittent starting issue
Old Mar 4, 2022
Rgon777's Avatar
Rgon777 is an unknown quantity at this point
Hey all, I'm having an issue when trying to start the car it may not crank but after trying a few times it eventually will. Not sure if it is coincidental but sometimes taking the key out and flipping it helps. Battery is good, I did replace the ignition switch which seemed to help for a couple weeks but now back to this random issue. Some days it starts no issue and others it might take a couple turns of the key. To me I automatically think a starter relay but this number 2 relay under the hood is nothing that I'm used to seeing. Do these types of relays go bad often?
It really feels like something is not allowing power to get to the starter. Once the power gets there it starts like normal. I'm stumped.
Old Mar 4, 2022
Re: 2014 Civic LX intermittent starting issue
if made in 2013 (Model year 2014) it lasted for 8 years, if made in 2014, lasted for 7 years.
but we don't hear much about starter relays failing.
potentially solenoid is stuck, wack the starter motor a few times and try again
Old Mar 4, 2022
you can also remove the starter motor and test it to see if gear pops out and spins
do you hear any noises when turning the key but doesn't crank?
Old Mar 5, 2022
Rgon777's Avatar
Usually no noises but sometimes a single click. Then a few more attempts and it starts right up. I'll probably just remove the starter and get it tested.
Old Mar 6, 2022
Colin42's Avatar
You can test it yourself with jumper cables, might need a screwdriver as well
Old Jun 25, 2023
MEL69's Avatar
MEL69 is an unknown quantity at this point
Did you get it fixed or found the actual problem. Mine is doing the exact samething
Old Jul 25, 2023
emich's Avatar
emich is an unknown quantity at this point
Same problem here. 2013 LX 150k mi. When turning the key a single click and starter not engaging. Battery and terminals, starter relay, neutral safety switch are OK. Turning the key second or third time or shifting the gear N to D and back to N helps.
Kyle Clark
Electrical
Jan 12, 2024 10:55 AM
Neo789
Mar 6, 2019 02:33 PM
Josh Phillips
Jan 12, 2018 07:45 PM
dsj09b
Feb 7, 2014 03:45 PM
richs1000
Aug 15, 2010 12:14 PM
